996TT DME report opinion
Looking at a 2003 996 Turbo.
71k miles
Now for the concern, DME:
Range 1
# of ignitions: 22228 2272.4h
Range 2
# of ignitions: 462 2214.5h
Operating Hours
2290
Needs new front brake rotors and the wing motors will need replacing.
I can get it for low 30's but this car has been tracked, pushed, and abused (I am assuming). Should I run or roll the dice?
Old 10-12-2016, 03:46 PM
Does it have a tune. With the rev limit raised?
That would explain things.
Old 10-12-2016, 06:07 PM
pushed and abused, maybe. Tracked, normally you see a lot of nosebleed mods, like the ****ing scrotch harness that everybody seems to think is a must have. And welded coolant lines.
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment."
Old 10-12-2016, 07:15 PM
Greek to me.
Old 10-12-2016, 09:06 PM
Worry more about the knock you described on Rennlist. I'd pass based on that, not the DME.
Old 10-12-2016, 09:14 PM
Originally Posted by revkev View Post
Greek to me.
Ecu reflash?
Old 10-12-2016, 09:15 PM
Alan....agreed. Having a 2nd mechanic check it out.
Old 10-12-2016, 09:26 PM
Greek to me.
The DME over rev report shows when the engine's RPMs went above a hard-encoded number in the computer. If the car's rev limit was raised, common in many aftermarket tunes, a simple and safe redline run can show up as over revs in the lower ranges.
Old 10-12-2016, 10:15 PM
Originally Posted by Skwerl View Post
The DME over rev report shows when the engine's RPMs went above a hard-encoded number in the computer. If the car's rev limit was raised, common in many aftermarket tunes, a simple and safe redline run can show up as an over rev.
Ahhh, thank you.
Old 10-12-2016, 10:16 PM
SalParadise's Avatar
I think the price is right as you're not going to find one less expensive than that.
Old 10-13-2016, 09:38 AM
techweenie's Avatar
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-13-2016, 03:32 PM
Functionista
manbridge 74's Avatar
Range 3 and 4 are a better indicator. Does it only have first two ranges on this model?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-13-2016, 04:58 PM
