996TT DME report opinion
Looking at a 2003 996 Turbo.
71k miles Now for the concern, DME: Range 1 # of ignitions: 22228 2272.4h Range 2 # of ignitions: 462 2214.5h Operating Hours 2290 Needs new front brake rotors and the wing motors will need replacing. I can get it for low 30's but this car has been tracked, pushed, and abused (I am assuming). Should I run or roll the dice? Last edited by revkev; 10-12-2016 at 03:50 PM.. |
Does it have a tune. With the rev limit raised?
That would explain things. |
pushed and abused, maybe. Tracked, normally you see a lot of nosebleed mods, like the ****ing scrotch harness that everybody seems to think is a must have. And welded coolant lines.
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment." |
Worry more about the knock you described on Rennlist. I'd pass based on that, not the DME.
Alan....agreed. Having a 2nd mechanic check it out.
I think the price is right as you're not going to find one less expensive than that.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Functionista
Range 3 and 4 are a better indicator. Does it only have first two ranges on this model?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
