is this a place i might get some general advice on a longhood 911 restoration?
________________ '68 911 targa '69 912 coupe '84 audi coupe gt '91 audi 200 tq |
What is the name of this forum?
Right forum (pelican) wrong subforum
Sent from my ONEPLUS A3000 using Tapatalk
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment." |
sbaklava.
Welcome to Pelican! You'll find plenty of restoration info over on the technical forum.
Kurt |
War Vet
Start a thread here:
Porsche 911 Technical Forum - Pelican Parts Technical BBS Also, there are specific sub-forums related to bodywork, engine etc... MattR
Dr. Phatt |
the name of the forum is Porsche Marketplace Discussion, and, guess what, i have a question about a Porsche i'm restoring and decisions i need to make that might effect it's position in the Marketplace and about which i'd like to have a Discussion.
but thanks all the same for the snark.
i don't have a technical question.
i'm restoring a numbers matching '68 911 SWT and had a question about upgrades—turbo tie rods, carrera chain tensioner, dual circuit brakes, ignition, fuel pump location, displacement/hp bump—and their impact on resale value. any thoughts? thanks.
War Vet
Being completely original obviously brings the most value. You are narrowing your audience a bit with modifications, but that isn't necessarily a bad thing.
Make sure all of your upgrades are reversible to stock if possible, there should be a negligible hit. Save all the original components. Mattr
Dr. Phatt |
My own opinion is against doing the pressure-fed tensioner upgrade. I prefer 930 tensioners with collars. You get the protection and avoid the non-stock look. But that's just me...
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Welcome to the Nuthouse. ![]() I think the type of changes that are accepted also vary based on the condition, miles and originality of the car. If it's a very original sub 80K mile car with original paint the changes will affect the value. If its a high mileage car with one or more repaints it won't matter that much.
Derrick Last edited by 1979-930; 10-26-2016 at 08:55 AM.. |
War Vet
what he said... MattR
Dr. Phatt |
i've always intended to restore this car as a driver. it sat for ~30yrs after a blown engine so there are no service records, no books, no jack, no meaningful provenance, and these are the things that bring top dollar for a concours car. add'l time and money in rust repair—no surprise there—led me to wonder if i shouldn't go for originality. but the upgrades, and these are the only upgrades i'm considering, are for good reason:
turbo tie rods, durability dual circuit brakes, safety ignition, reliability carrera chain tensioner, durability, though the 930 solution may be adequate relocate fuel pump, reliability and performance place it either in the newer location within the engine bay or move it up front. both stock locations, just not in '68 displacement/hp bump because the engine sat unsealed for so long, one bank was seized and required some effort to pull it apart and some machining to prep it for reassembly. the suggestion is to rebuild as a 2.2L, w/ E cams, S p&c, minimal change in appearance. BIG change in performance. and this is a straight 911 so it came from the factory with weber carbs and ventilated discs.
________________ '68 911 targa '69 912 coupe '84 audi coupe gt '91 audi 200 tq Last edited by sbaklava; 10-26-2016 at 09:50 AM.. |
Mighty Meatlocker Turbo
then we'll just have to hug it out.
I have a car just like yours. We serviced the engine and uprgraded the timing chain to hydraulic dampers. It cost close several k cdn$ . I felt it was an important upgrade. Email me and we can discuss your 68. Mine is an S Targa, no SW. I wish I had the SW. Brianvb@me.com
I Love Baklava
