Whats the value of my 1977 911.....very modded and updated
Folks, I'm going to be selling my '77 after 38 years of ownership in the next month or so and am trying to figure out what the value is.
I have just spent the last 4 months going through the car and making sure that everything works and it is cleaned up. It hasn't been on the road for the past 10 years but has been kept up with. Here is some info: 1977 Porsche 911S We are the second owner or this car which we purchased in 1979 and drove it pretty much stock till around 1987. Original Color Gran Prix White, Cork interior, power window, power sunroof. We know the history of this car and it has never been in an accident as long as we have had it. We don’t believe that the original owner we bought it from had any either. Car is straight and rust free. 1988 3.2 engine was professionally installed by a local Porsche mechanic 1992. Engine was purchased used from a local Porsche salvage shop (PAP) 1992 with about 22k miles on it and put in my car which had ~130K miles. I have put 36K total miles on engine and 15K since the last rebuild in 1995 which was done because I had the engine previously super charged and burned a piston. Engine was twin plugged during this rebuild and then supercharger was later removed after ~5K miles. So Total on engine is ~ 58K miles and ~15K miles since last top end rebuild. • Gran Prix White – This was a paint over original when we did the steel flairs in 1988. I’ve just had the paint gone over and it looks very nice for 30 year old Glasurite. • 930 Steel Factory Flares welded on ~ 1988 • AIR 930S Front Valance Fiberglass ~1988 • Front Brake cooler holes in Valance are functional • Passenger Electric Mirror Added , both work • Air conditioned car but I have the Compressor and Rear Condenser out but have them, so the system can be made complete. Last time this air was run it was on the old R12 so it would have to be converted to the new Freon • Electric Windows and electric sunroof, all work • Black on hood and tail are Avery Supreme Satin Black film • Just spent over $3500 on parts and 5 months getting the car in first class shape ready to sell. Suspension • Weltmeister Cambermeister strut brace • 22mm Weltmeister through body front sway bar • 22mm Weltmeister rear sway bar • 19mm 930 Front Torsion Bars • 26mm 930 Rear Torsion Bars • Bilstien Sport Front Shocks • Bilstien Sport Rear Shocks • Lowered • Turbo Tie Rod Ends • Bump Steer Kit • Front end rebuilt ~1993 when new engine went in • New HD bushings installed when the new torsion bars and shocks were done • OZ racing wheels just Plasti Koted black. They were originally gold but was looking for a more modern look. Plasti Kote can be peeled off if you want he original gold look. • New Rakin Raptor Tires (made by Michelin). 225/50/16 front, 245/50/16 rear. I choose these because they have very good reviews, are all W rated unlike the RE11’s. I also went to a 50 on the rear sidewall to make street driving smoother with the tight suspension in the car • Spare tire and toolkit (shows it’s age but tire looks good) • Cleaned and coated front suspension parts with Por15 Brakes: • Stainless Steel Brake Lines • 930 Turbo Front & Rear Calipers (Rears and spacers redrilled by VCI) http://www.vehiclecraft.com/Brakes/930_upgrade.htm • Vehicle Craft Inc (VCI) Drilled rear and Slotted Front discs • Brakes are non floating • Larger 23mm Master Cylinder • Front Brake Cooler backs hooked up to front valance with new silicon cooling hoses • Brake Fluid ATE Super Blue (NOS I had) • Extra set of used but lots left Pagid Orange pads for track DE use Interior • Cork color • Just refinished dash, kneepads, and door armrests with Genuine German Cork Vinyl • Like new RS America Black cloth 4 way power seats (Up/Dn front and rear) By far the best sport seats I’ve ever had • Drivers seat rails are made from Carbon Fiber and were lowered ~1.5” as well as allow the seat to be mounted in 3 positions providing more leg room. Front mounting holes are standard position. With the RS America seats you have a LOT of upward travel and you can easily mount a racing seat of you want. I’m 6’4” and have a lot of leg and head room • Just installed new Appbiz Lightweight Domestic Black Carpet • Rear seats are out but I have them with mounting hardware • Fixed drivers and pass door pockets while doing carpet • Bolt in Roll Bar • Momo Steering Wheel and adapter to push wheel back a bit • Upper Steering shim just replaced to remove up down slop • Black leather covered Momo shifter knob • Driver is set up for 5 point harness, Pass for 4 point, belts not included • Upgraded Tach face by North Hollywood (I think) so redline is up and you don’t have to rotate your tach. It reads a bit high on idle but has been checked on top end and is accurate. Read a bit high at idle but has been checked at top end for accuracy • Sony Amp under Pass Seat • Removable rear shelf with 2 JL Audio Subwoofers. Can easily be removed for those track days with two screws • New driver and pass floor wood pieces just put in. • Replaced Visors with the kind that don’t disintegrate and dyed the same color as headliner, Ivory • Just re-dyed headliner stock color, Ivory • Windshield replaced ~30K miles ago • Dead Pedal or foot rest for left foot while driving (keep foot off clutch) Motor and Trans • 1988 3.2L Motor Purchased in 1992 from PAP w/ 22K miles on motor and ~130K miles on car • Motor top end 3.2L rebuilt ~15K Miles ago and made twin plug. Reason for rebuild was previously installed supercharger burned one of the pistons. • Compression warm (PSI) 170,170,164,170,170,165 • Leak Down cold <3%, <3%, 3%, 3%, <3%, 4% . No leaking can be heard from intake, oil tank or exhaust No broken head studs, checked during recent valve adjust. • Trans 915 w/ ZF LSD gone through ~30K miles ago • Replaced Engine Support Bar during engine swap • SSI exhaust • Stock 2 in 1 out muffler that was opened a bit and a larger SS tip welded on. Looks good and sounds good!! But not to loud and annoying • Twin Plug, heads machining by Ollies • Porsche twin plug distributor from 3.6 motor just rebuilt and new belt added • High Voltage silicon ignition wires recommended by Crane, NGK B8ES plugs top and bottom • New rubber distributor caps just replaced • Lower plug hold downs • Turbo Valve Covers • Dual Crane HI-6 CD boxes and Dual Crane PS-92 Coils to drive twin plugs that works with DME • New engine compartment heat/sound shield just installed • Oil, Filter and Fuel Filter just changed. The fuel filter was cut open after running it for period to insure here wasn’t any contamination from the refinishing of the fuel tank.. Nothing found in filter. • Fuel system was flushed out and fuel tank removed, cleaned and coated inside with Bill Hirsch Sealer inside making sure none got on the stir pot. Tank was coated with Por 15 on the bottom outside and texture put back on and repainted black on bottom, standard grey on top • Earls Front Oil Cooler • New battery (just replaced) • Electrical Kill Switch • Motor and trans mounts replaced with heavy duty versions • Shifter connector replaced • Performance Clutch • Autothority Chip. SW wasn’t around when I did this but I’m sure his chip could extract some more HP if the engine is described to him • Short Shift Kit • New Oil Pressure sender (just replaced) • K&N Air Filter (just cleaned) • New Fan Belt (just replaced) • Valves adjusted • Just changed Trans fluid with Kendall 80-w-90 GL-5 with LSD additive • No oil leaks anywhere on engine or trans Body • H4 lights and painted rings • New bulbs all around and all lights operate • Refinished front and rear running lights and new seals in rear • New HD hood lifts (just installed) that are supposed to be guaranteed for life. • Tail is a 3.8 RSR with Carbon Fiber wing from TRG. If you prefer the older 930 tail I’m sure this one could be sold to more than cover the costs • AIR 930S Front Spoiler with Fog Light opening modded to brake coolers • The huge rear heavy US rubber bumpers were removed to save weight in the rear. I still have them if you want to put them back on. Holes were filled with JB weld so you can see them from the back side if you want to redrill them and put the heavy bumpers back on • New windshield rubber when I did the dash and new drivers window felt and outer felt both sides and rubber both sides. • All fuses just changed to new ones • Undercoating was put on by PO, I just refreshed it cleaning some of the old off and shooting new in the wheel wells. • Wrap in satin black on hood and tail. This can be easily removed if you want all white. Reason this was done is to give a more hot rod look. Should be good for 10 years if car is kept inside. Extras • Brake pads used (lots of life) front and rear • Compressor, mount and rear condenser if you want to make the AC work again. If it were me I’d take the rest of the AC components out and lighten the car as the AC on these early cars isn’t very good and I did everything to try and make it very cold. It has the additional front condenser and blower installed. • Rear Seats and seat backs re-carpeted but out of car. I have all the bolts if you want to reinstall. • Most receipts since we owned it • Copies of 3.2 Engine and trans factory service manuals • Fog Lights, rear turbo fog lite • Rear heavy US bumpers • Many other extras, essentially everything I saved since ownership. What does the car need? • If you want A/C you will need to re-install the compressor and rear condenser and convert to R134A. • At some point you will need to replace the rear window seal It’s more of a cosmetic thing. • The engine deck shocks don’t hold the rear deck lid up. I gave up on replacing these years ago as they don’t last very long. • The dash brake/fasten seat belt light hasn’t worked in years and I couldn’t figure out how to fix it. I suspect bulbs need to be replaced So what do you think? Thanks, Terry |
Terry your description is awesome.
Please add photographs. It's easy to do on Pelican, it has a Click Here To Upload Photos button. I really would like to see it because I am really into midyears. |
BTW, compared to other forums the few times I put pics on here I found slow and difficult. Terry |
It looks like a serious commitment to a midyear. I don't see many '77s - most were modded with flatnoses/side intakes/turbo tails/cheese-ball interiors (ie white gauges) and three-blade wipers. Arguably, the '77, like mine (a '75 S) were probably bottom-of-the-barrel 911s five years ago. Now things have really changed and it's a good market to sell. It only took 30 years for people to wake up to the finer things in life... |
OK here are some pictures I snapped out in my shop. Sorry for the bad quality and there is dust all over the car outside.
My feeling is that the tires will be up to the new owner as there are lots of good choices out there. I have BFG Comp T/A's on it which I really liked but they are showing some cracking from age. Terryhttp://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG http://forums.pelicanparts.com/uploa...1491569784.JPG |
Really like the seats a lot. Had leather sport seats at one time but you slide to much on leather and the RSA seats were much better. The only thing wrong with the mid year cars was the mag case on the engine. But adjustments could be made to that during a rebuild. Mine was in the car 130K miles without a rebuild and was still going strong (with good maintenance) when I had the 3.2 put in. Terry |
Tough one as the audience is narrowed to hot rod Porsche guys. A lot of money in this one that may not see back unless you find the right buyer. I'm biased, but I like all the mods and I like mid-years. No offense, but I think the cork is a minus. And BBS are a minus (though I personally love them) What injection system do you have? Can we see a picture of the engine bay and underneath the engine? Are you looking to trade or cash out?
I think it's awesome. It is probably one of the most tasteful modded '77s I've seen.
Getting back money will be tough, but people 'in the know' will appreciate the simpler midyear starting point. Personally, as said above I'm not a fan of any gold BBSs on anything - except maybe a 1987 red VW GTI. The market is tough on cars like this. You'd have to find the right person, and it's much easier thanks to the internet. I'd get it all back together and cleaned very well and put it on BaT. I wouldn't be surprised at $28-$32K - to the right person. |
I might go higher than that. I was thinking high 30s maybe more. That frunk is spotless. If the rest of the car looks that clean, that's a super solid car. Knowing the costs of a widebody conversion, a twin spark 3.2, 930 brakes - those are all big dollar mods. Finish putting it back together, and murder out the BBS I think they look really killer all black- and get a pro photographer to snap some 'stanceworks' style photos and you may appeal to younger Porsche enthusiasts with money looking for an RWB type look and couldn't care less about originality.
I don't ever expect to get back what I have in this car over the years I've owned it. Went through my receipts the other days and no way. Heck the brakes alone are what $5K?
What I am trying to decide is if it's worth it to continue on or part it out? It is a very reliable car with great cold and hot starts. Corners and stops like mad. Motor is essentially stock except for the twin plug setup. Injectors are stock but I did pull the fuel rails and injectors to clean them a few months ago and replaced the o rings and screens in the injectors. They didn't need it as they were clean as were the rails and fuel lines. There are absolutely no oil leaks or broken studs. I had the DME professionally gone through when we installed the engine (essentially to insure no cold solder joints) and I just opened it to insure there isn't any corrosion which there wasn't. I also worked with Crane on installing the twin plug system and replaced the belt in the 3.6 distributor a month ago although it didn't need it. Man with the EFI systems out here now, I would be really into doing coil overs plugs and programmable FI. Megasquirt and others look very interesting. Terry http://forums.pelicanparts.com/uploa...1491572973.JPG |
The wheels BTW are OZ Racing MSW 3 piece. Black? When I finish the car I will have it professionally photographed. Terry |
It looks unbelievably clean. Like mine. Babied. Sounds like you need to get out and drive. Since the refresh have you driven it much?
-Edit, oh I see your knee comment. Parting it out might be tough emotionally. You would have no problem getting good money for the parts. |
Yea the knees are the biggest problem for me driving it. Since the 3.2 I drove it 30K+ miles and did some DE with it so I had my fun. My wife drove it the first 50K or so miles and then I took it over so I have quite a few miles on it.
Time to let someone else enjoy it. Terry |
To maximize your money you'd have to do the following:
1) Detail it. I mean really detail it. 2) Put other rims on it (sorry, but the gold BBSs are dated and that's the now 2017 game). Then you'd have to add tires. I know this is money but it would be worth it. 3) Get it running and drive it. And I mean drive it. Get real numbers on leakdowns and compression and post photographs of the findings. 4) Get photos of all corners. 5) Sort everything that needs to be sorted. 6) No way that current rear tail that you speak of in the year 2017 is going to be that marketable. I would market it as a hotrod. To get all the money as has been said it's going to take a few weeks (or months) of work. The difference in my estimate and $39K is only $7K. $7K gets eaten up very quickly when you consider tires, rims, and a real tail that someone in 2017 actually wants on their car and wants to look at. If you want all the money then you have to add the stuff that people actually want - or they will discount accordingly. Problem is, when people come up with estimates they are always thinking of 'What the car could be' in their minds - not in its present state. I made an educated estimate on what I think it's worth as I've followed midyear auctions - not what it could be worth, off the jackstands and with some cosmetic (for the year 2017 preference) additions that will add value. |
This is really a stand out car. With the 3.2, it must be a killer ride.
Even though it is a 'work in progress' and incomplete right now, it is very clear that this car has been modified correctly over the years by a knowledgeable long-term owner who really has cared for it well. Judging by his detailed write up and his dedication to bring this car up to top mechanical condition after it's long-term storage, this car will sell easily. The high quality aftermarket parts and attention to detail along with the overall cleanliness of this car will bring a premium. The suspension on my 77 911 is set up similar to this one and I can tell you that it is awesome. Even this dash is perfect without any cracks and a ton of detail in the interior. I know the market prefers stock 911s but a well modified car in good condition also has value. I see the cork interior as a plus over the typical black interior but would prefer the seats to be cork also; even though I understand the logic of going with black only RSA cloth sport seats. I look forward to seeing this car when it is put back together. Hopefully the BBSs fill out the wheel wells correctly. When it's back on the ground, I'd ask $40k+ if I were selling. |
Sal,
Thanks for your insight. I appreciate it. I can certainly add tires to the car, no problem, but with so many good choices out here and this being a personal thing, I thought I'd leave that up to the buyer. But maybe not. On the rim's what if I finish them black as suggested earlier? I have been sorting out everything, and I mean everything for the past 3 months. It all works as it should except for the A/C (which I can put back in) and the seat belt/brakes light. I have replaced all defective parts and cleaned and finished as needed. The car had dust and pollen on it this morning when I took the pix so reflection isn't as good as it is. Do you hink that the tail should be changed? to a whale tail or even a duck tail (I can't believe how popular they have become, whats old is new I guess.....) Terry |
Put the car on Bring A Trailer (BAT) for maximum return....trust me. You'll be happy you did !
Yes the OZ Racing wheels fill out the wheel wells perfectly as the spacers are the correct ones front and rear. Terry |
Terry |
You could plasticote the wheels black then spray the gloss over on one to see how it looks. I was thinking sort of like this, one of my favorite cars on pelican:
http://forums.pelicanparts.com/uploa...1491575961.jpg http://forums.pelicanparts.com/uploa...1491575992.jpg Also, you will absolutely have to change the yellow fan / housing color out if you sell. Good luck. Amazing car! Post a follow up pic when it's backlit on the ground. |
Forget eBay - put a high reserve, one you would be comfortable with and put it on BaT - they love aircooled over there. |
I like the look of the blue wide body with no whale tale. The white one would look good like this too. Let see the current gold OZ wheels on it before doing anything.
Will do, I'll post a picture when I have it on the ground again in a few weeks with the OZ wheels gold.
But those black ones sure look good!! Terry |
Those RS America seats are rare and worth a pretty penny these days.
Man I really like this car. I am a mid year fan myself and this one is amazing. Timing is off for me unfortunately. Next year would have been better but thats how it goes.
I love this build and it would be expensive to replicate. looks to be very well done with a lot of details. I think you could get 35k+ . Midyears are hot sellers
I would be all over it, but have a hot rod 1988 targa. |
Thanks to everyone who participated in this thread giving me advise. Now that I understand the value I know that finishing the car and not parting it out is the right thing to do.
I'll continue to work on the car and have it available on BaT in about a month or less. I'll also post something in the Classifieds here and that other P site. Terry |
I would buy it the way it is, though I agree about making the wheels black. I really want a widebody, I like the contrast of black and cork, I like the yellow fan, and it has 90% of the mods I would do eventually. I'm definitely interested when you have it back together.
2) I really like the idea of blacking out the OZ Racing wheels with PlastiDip. Do everything including the rim like in the picture on this thread. Thoughts? 2) What tires. Back when I drove this car BFG Comp T/A's were he cats meow. Great grip but mot erasers like the Perelli P7's. But I haven't kept up with the times and don't know what are considered good reasonable street tires any more. That's why I was thinking I'd leave the tire choice up to the new owner and price accordingly. But I can see some wisdon in having the car "finished" so the new owner doesn't have to do anything but gas and oil and drive it. So what are good 2017 choices. 6) While I likes the looks and feel of the rs 3.8 CF wing tail on the car a lot, it may not be for everyone. Personally I think it balances pretty well with the AIR front spoiler I have. Here are a few pictures of tails like mine if you are unfamiliar. http://forums.pelicanparts.com/uploa...1491746323.jpg http://forums.pelicanparts.com/uploa...1491746323.jpg But again, I haven't kept up with the times and I see that duck tails have become insanely popular. I guess whats old is new again..... I have no problems changing the tail, but to what? Duck tail.....I never really likes them personally Early period correct whale tail? With or without rubber? Is a fiberglass aftermarket OK? Later SC Tea Tray whale tail. They look great and at one time had one on the car. Your thoughts would be appreciated. Terry |
Really like the rear qtr angle view and early script, I bet it would great with bright trim:
http://forums.pelicanparts.com/uploa...1491747646.jpg |
First, where are you located? I think that can make a difference as to price and how long it takes to sell.
Second, this car looks and sounds (by the description) great. There are more hot rod lovers out there than people might think, and this car seems well built. Don't forget we're on PP, an enthusiast site. Third, I would never buy a car of this supposed quality and modifications without driving it, hard, first. Fourth, I would also have it thoroughly checked out by a Porsche specialist (beyond your normal PPI) because of the modifications and how they actually work on the car. Fifth, low $30's my butt. If this car is everything it's cracked up to be, it's a $40K car all day long. Sixth, I wouldn't change anything. Sure Fuchs would look better and other visual cues improve your potential audience, but a crazy cool, fast Porsche hot rod with a detailed back up inspection from a highly qualified shop (that YOU get before you market the car) will sell quickly at a price below $40k. Just my 2 cents. GLWS Nick |
Thanks NYNick,
Car is located in Georgia, in the US Terry |
What you can do is keep everything the way it is - but please replace the old tires.
Keep it what it is - and sell your own vision. The wheels, tail, etc are not my cup of tea but it's maybe a lot of peoples' cup of beer, so in keeping it the way it is saves money. Saves a lot of money. And why the hell not in some ways - and those ways it's sort of a period correct ('80s period) hot rod. It's way too much tail for me but who the heck knows? I don't like a tail on almost anything or gold BBS wheels - but there are a lot that do. If you put it out there and sell it knowing you're selling your own vision (but safe one, with new tires) maybe someone will dig it. You've got nothing to lose. |
Thanks for the advise on Plasti Dip on the wheels. I did the OZ Racing 3 piece wheels in black and now it has a new bad a$$ look much nicer than the dated gold wheels like the pictures above. Did a lot of research on this (over thinking it) before I shot the wheels and it came out very nice. And the nice thing about Plasti Dip is if the new owner want to return them to the original gold color they can. Car has new tires, new brake duct hoses, all of the front suspension cleaned and coated with Por15, etc, etc, etc. I'll post some new pictures next week when I'm finished before it goes up for sale. Terry |
Here are a few pics of the car which is getting close to being on the ground permanently.
The black on the hood and tail are Avery Supreme Satin black wrap which gives it a nice look with the black wheels. Two people that have seen it thought I painted the black.......nice. Terryhttp://forums.pelicanparts.com/uploa...1496353959.JPG http://forums.pelicanparts.com/uploa...1496353959.JPG http://forums.pelicanparts.com/uploa...1496353959.JPG |
As mentioned earlier, this is a great BaT car. Look at the recent auction results for modified 911s over there. For this 911, all the boxes are checked.....knowledgeable, long-term owner and a car that is in great shape/well detailed. Take lots of pics of the underside, suspension and engine bay. The BaT peanut gallery will try to pick it apart but this car will stand up to the noise. Good luck.
Yes, right now BaT is my first choice for listing the car. We'll see if I can work with them.
I'm pretty thick skinned so I think I can handle the "noise" I didn't know if I was going to like the satin black hood / tail look but I think I nailed it the color. Just enough shine. Flat or matt black just wouldn't have looked as good IMO. Terry |
Some of the pictures with the car almost complete. Have some P stickers coming for the wheels and am considering putting a glossifier coat on the wheels to make them shine a bit more instead of the matt black they are?
I've been in touch with BaT and will upload pictures today and see how it goes. Terryhttp://forums.pelicanparts.com/uploa...1497187625.JPG http://forums.pelicanparts.com/uploa...1497187625.JPG http://forums.pelicanparts.com/uploa...1497187625.JPG http://forums.pelicanparts.com/uploa...1497187625.JPGhttp://forums.pelicanparts.com/uploa...1497188128.JPG http://forums.pelicanparts.com/uploa...1497187625.JPG http://forums.pelicanparts.com/uploa...1497188128.JPG http://forums.pelicanparts.com/uploa...1497187625.JPG http://forums.pelicanparts.com/uploa...1497187625.JPG |
Wow! That looks absolutely killer! Good choice to keep the wing and do the black wrap as it really compliments the wheels and gives it a very aggressive look. I like the fact that it has the mods to back up the look too.
The thing I like about BaT is that it lets you tell the story of the car -and part of the story is the care that's gone into the mods and just the level of detail. This is one clean car. Let us know when you list it on BaT if it makes it that far. I think you might get some offers before hand. Maybe throw it up on Pelican classified and see what bites you get. |
| All times are GMT -8. The time now is 01:45 PM. |
