2.0 motor & trans from 1969 911T value?
Hello all,
I'm looking for some advice on value.
I've acquired a ton of parts over the years of building, trading, flipping, wheeling and dealing.
I have a 2.0 motor and trans from a 1969T 911. They were removed from a car I drove 5 years ago. Been sitting in storage since. The motor was strong and ran well. I have no other info than that. I'm trying to clean up the warehouse and down to one P-car and will be for some time.
Time to move some stuff!
The motor is complete but has the fan, shroud and carbs removed (although I do have them).
Any suggestions as to the value?
Should I sell the Zenith carbs and transmission separate? I'm not looking to get top dollar just clean up the shop.
Thanks in advance!
PS. I don't have the engine number handy but will get that in the next few days....Located in Sacramento.
Update after some research. Engine number 6196398 shows it to be a 69 T engine.
Again, thanks all for any opinions as to value.
Old 04-18-2018, 08:09 PM
Engine Type number?
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 04-18-2018, 08:29 PM
Mag or alum? huge difference
Old 04-18-2018, 08:35 PM
I was able to track down the engine number from old notes I had. It appears (if my online detective work is accurate) the motor is from a 1969T
Engine number 6196398 shows it to be a 69 T model.
Still looking for advice as to the value.
Thanks again!
Old 04-18-2018, 09:42 PM
IMHO, the least valuable 911 engine.
Old 04-19-2018, 06:12 AM
I think that is a common opinion.
$2,000 at most.
Old 04-19-2018, 07:15 AM
If the motor is complete with carbs it's worth quite a bit more than $2,000 even if it is only a 69T, which yes was the least valuable motor. You're probably looking in the $5,000 range. You might also post the transmission type. That will affect it's value as it could have had any transmission.
Old 04-19-2018, 07:46 AM
But the carbs would likely be IDTs, again the least valuable.
Old 04-19-2018, 07:48 AM
gearhead
This.
It will likely be a 901/13. Mag case. AFMSZ. Worth about $1000 on its own.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-19-2018, 08:42 AM
Thanks all!
Old 04-19-2018, 12:07 PM
I really hope you guys are right and I am wrong, I have a disassembled 69T motor I would like to sell.
I was thinking the case was worth only $400, and the non-CC Std. Std. crank at $300.
I had the heads a the LA swap meet twice and finial let them go for $200.00 so I did not have to drag them back a third time.
Old 04-19-2018, 12:14 PM
