keitho64's Avatar
Aftermarket seat installation - question on seat belt receiver
I have a pair of Recaro seats that were in my 1969 911 and I am planning to install them in the 996. On the old 911 the seat belt receiver was connected to the chassis of the car. I noticed on the 996 the seat belt receiver latch is bolted to the factory seat.
For reference my factory seats are power, no lumbar, no heat. There is a module under the seat that connects to the motors as well as a small connection to the seat belt latch.
For those of you who have done this mod I have a few questions.
Where did you mount the seat belt receiver? to the slider? to the seat? to the chassis?
If you mounted it to the slider, did you add a bracket to bolt the factory receiver to?
Did you reconnect the seat belt harness?
Did you have an issues leaving the module mounted to the floor?
Thanks in advance!
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 06-20-2023, 01:19 PM
mistertate's Avatar
I did this on my 03 boxster. Bought a used receiver off eBay, shortened it a little by welding a tab on with an 8mm hole. Bolted it on where the seat bolts to the side bracket. Now that I think about it, M8 is probably questionable but I’m actually redoing it to use Schroth harness and a bigger bolt so I guess I survived.
I just plugged the receiver wire into the harness and tied it to the bottom of the seat. I did all this with the battery disconnected and didn’t get an airbag light when I put it back together.
dude
Old 06-24-2023, 08:03 PM
