meister member
need advice ASAP new injector seals leaking!!!
I installed the cam tower and I resealed the injectors using the pelican parts kit. I used new O-rings on both ends but used the same washer. When I try the spacer that came with the kit it doesn't look right. The hat doesn't sit all the way down on the injector. It seems like the injector O-ring isn't going all the way into the intake manifold hole even though I push like a motha.
Advice please. I need this assembled before dark. Thanks, Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Did you lube up the O-rings?
New ones are a tight fit, but they will go in with some effort. Silicone lube, ATF, or vaseline work well. The new spacer will be a little "crooked" that is normal. Everything lines up when you press it all in. AFJ
meister member
So I should use the thicker spacer even though the hat doesn't go down all the way when compared to the old ones?
meister member
I used the taller washer and no leak.
It just didn't look right but if it doesn't leak...Speedy
Cars & Coffee Killer
Be careful Speedy. The last time I did this I ended up selling a car to you...
![]() Oh, and make sure none of the lines to the fuel rail cracked when you moved it out of the way.
meister member
Besides we can always do a "I buy yours and you buy mine" program. ![]() Speedy
Sounds like you have all of your bases covered.
The hats should push on all the way until the pin is pretty much flush with the face of the injector cap. Otherwise it will affect the spray pattern.
