Fan motors
Is there such a part as an amplifer that goes to front fan motors? If so where is it?
Wayne |
Just thinking out loud
What year, and model is the car?
83 944 91 FJ80 84 Ram Charger (now gone) |
fuse, relay and thermal switch are what i'm familiar with.
87951
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
No amp. As replied thermal switch on radiator, relay and two fuses -one for each fan. On the early 944's there is a balast resitor to run one fan at a slow speed after the engine is stopped. The thermal switch controls when the fan stops.
On the later 944's there is a balast to run the fans at two speeds; medium and high, while driving and one fan at the low speed after the engine is turned off. What year and what is the actual problem?
Thank you for your reply. I have replaced switch on radiator., new relay, fuses are okay, but the fans will still not start running. The fans run when hot wired. I have just run out of what to check.
Wayne Last edited by Wayne Hall; 10-22-2006 at 01:27 PM.. |
Forgot to tell you it is a 1987-944 nonturbo,
Wayne |
Pull the connector on the radiator temp switch. Short pin 3 to pin 2. This is the lower temp. The fans should run medium speed. May need to turn the ignition on. If not then you need to pull the gove box and check out the fan resistors. These might have failed. Think they have short circuit protection on them. Bi-metalic spring switch.
