996 Air Oil Separator Question
I've read about the air oil separators failing on these 996's in a few threads. However, none of these threads are really detailed on this topic. Where is this air oil separator exactly located at? What does it look like? (A pic would be great!) How hard is it to change? Is this an expensive part? Any recommendations on the best place to purchase one from? I want to replace it before it starts causing me trouble!
Old 01-02-2010, 10:36 PM
It located on the drivers side (1-3) on top the engine towards the flywheel. Very difficult to change without dropping the transmission. Sunset or Suncoast Porsche sells them for about $120.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 01-03-2010, 04:30 AM
Thank you rb101!
Old 01-03-2010, 06:47 AM
Mookster's Avatar
My vehicle is a 2003 996 Cab
I had coolant leaking (dripping) on the left side of the motor when the oil-air separator failed, 51,000 miles.
I replaced the coolant expansion tank and several coolant hoses during this repair while the engine was lowered.
Part cost $114.56
Total labor for all the repairs 5.5 hours (oil/air separator, coolant expansion tank, hoses and diagnostic).
My suggestion, if the engine and tranny are out replace the parts and hoses, if not leave it alone. It is never just replacing a single part.
Good luck.
If it has a skirt or tires, it WILL cost you money!
Old 01-03-2010, 07:49 AM
Part cost $114.56
Good luck.
Thanks! My engine has approximately 50K miles on it now. The engine is going to be out, so I would like to address any potential upcoming issues at this time. Where did you find the air oil separator for $114.56? That's a good price.
Old 01-04-2010, 02:56 PM
Mookster's Avatar
The part cost was with 10% PCA discount from local independent mechanic.
While the engine is out you want to complete the 60k service as outlined in the owners manual.
My suggestions not considering a budget and in no order:
1. Replace the belt and tension pulleys
2. Replace coolant hoses. The hoses are not cheap but with the motor out this is the time to do it.
3. Replace the coolant expansion tank and upgrade the cap
4. Replace the water pump....on most vehicles they go bad at 80-100k miles.
5. Replace the clutch assy if it has not already replaced. Base on discussion with my mechanic they have been going bad at 35k to 50k miles. Mine went kaput at 40k miles.
5. Upgrade the clutch fork
6. Replace the engine mounts.
7. Detail the motor
8. Replace the engine sensors that are hard to reach with the motor installed.
9. Address any leaks or potential leaks
My intension is not to spend your hard earned lunch money. What I have learned in my Porsche ownership is to take advantage of the over lapping processes when you can.
Good luck
Old 01-04-2010, 05:05 PM
Owner, Callas Rennsport
TCallas's Avatar
bxtech, here is an article I have wrote for the PCA. Maybe it can shed some light on your quest.
Porsche Engine Oil/Air Separators 101
The Engine oil air separator directly affects the engine crankcase atmosphere because basically all Porsches from 1980 on including the current 986-987-996-997-Caymen & Cayenne engines all are positive crankcase type systems meaning the engine crankcase has vacuum supplied from the intake manifold to collect and burn the residual combustion by-products or blow-by in the crankcase by running it through the engine again, basically to lower the overall vehicle emissions.
On most occasions, when the oil separator fails, intake vacuum in the engine crankcase rises to an unusually high or abnormally high figure and more likely than not ends up drawing engine oil into the intake system usually fouling spark plugs and even possibly causing damage to the oxygen sensors (O2), catalytic convertors and even possibly various other sensitive fuel injection components.
Interestingly enough, the only way to test the oil separator is to periodically test the engine crankcase vacuum with a water filled Monometer AKA an ultrasensitive vacuum gauge. On BMW’s and Porsche’s, the engine crankcase vacuum is normally around 4-7” (Inches) of water. When these oil separators fail the crankcase vacuum can rise to 9-12” and even higher depending on the extent of the failure.
When the oil separator is starting to fail on Boxsters (986-987), generally you will start to see a substantial amount of smoke from the exhaust tailpipe. When the oil separator finally fails, the engine exhaust smoke can reach dangerous proportions that almost look like it was manufactured from an anti-mosquito smoke machine. Unusually enough, on the 999-997’s, when the oil separator fails, it hardly ever creates any exhaust tailpipe smoke, almost being like a silent killer or costly surprise.
On another note, it has been known on rare occasions, that when an oil separator fails that it is possible to have a slightly rich running condition that might turn on the check engine light or CEL. The only way to know what is happening is to check the fuel trim numbers on the OBD-II “Freeze Frame” data and crankcase vacuum to see exactly what’s going on, otherwise your just guessing.
Tony Callas
Phone: 310-370-7038
Located in the Greater Los Angeles Area
http://www.callasrennsport.com
Old 01-04-2010, 06:44 PM
Thanks Mookster for the extensive list. Very helpful. A lot of those things on your list are things that I was already planning to address since the engine is out. I don't want to have to pull the engine again in the near future! No fun!
Old 01-13-2010, 06:44 PM
Thanks Tony Callas for your very informative article. It gives me a clear "picture" of what is actually happening, and what this particular part actually does. Being a "silent killer" is kind of scary. What is the general recommendation for these? Replace it when the engine is out just to be safe? It doesn't seem like these go for many miles. Mookster's failed at 51K miles and mine is at about 50K miles right now! I am planning to change mine so I don't have to worry about it for awhile. What do you think? I would perform the test, but I do not have the proper equipment to do so, and it would probably cost me more in labor to have it done than just to replace the part!
Old 01-13-2010, 06:47 PM
Tony Callas,
I am going through some sort of problem similar to what you described and i am leaning towards an AOS,but i dont have the experience nor the equipment to do it.
My car was running fine a couple of weeks ago when i just went and parked it in the garage, yesterday i started it and first it was iddling really poorly and it would die eventually after 15 20 seconds so i re started the car several times and gave it gas while idling and it still had a very rough idle then if i depress the gas pedal too much it would back fire, finally it started smoking real bad, white color smoke that rapidly made everything foggy, i didnt go and check if smoke was coming out of both tailpipes but it seemed to idle slightly better,but then again if i would let it idle without giving it more gas it would die.
I had a continues CEL and then it turned into an intermittent one.
Could you please give me some advice in regards this problem? i am taking the car in to have it scanned and serviced monday morning although i am having it towed tomorrow afternoon.
Thank you for your time and help.
94 Carrera 2
99 Carrera 2
93 Corrado SLC supercharged
86 Kawasaki LTD 454
Old 01-14-2010, 04:50 PM
Pacific996's Avatar
afast16v I don't know how cold the temp has been lately in Oregon but my first experience with fuel injected engines was finding out how they start hard in cold weather. If your spark plugs and wires aren't good and the fueling with air don't clear chambers you can be looking at the same problem. It isn't always the air oil seperator. You can wipe a finger on the inside of the tail pipes to check for a fuel smell or signs of oil after a hard start like that. Being it was a cold start and it didn't kick over right away I'm thinking it wasn't the AOS. Probably a full tune up will fix things. If everything else was running good I'd think the engine would fisrt start then after a good strong start you'ld get trouble from an AOS related maledy. At least i don't think an air oil seperator problem is an instant engine killer after sitting for a couple of weeks. Change the air filter, spark plugs and even the wires if they have been on the car for it's life and see what else the shop has to say.
Old 01-14-2010, 11:01 PM
TCallas's Avatar
The only way to see if the AOS is OK is to check the crankcase vacuum. We have come up with a Manometer assembly that taps into the crankcase via the engine oil cap. This is the only way I know of to properly check the engine oil separator, without guess work. It takes me minutes to perform this procedure. I travel all over the USA and Canada teaching technicians my ideas on this, all promoted and sponsored through a company called Worldpac Training Institute. My next class is in Gaithersburg, MD next month.
WORLDPAC - Advanced Technical Training Program
Tony Callas
Phone: 310-370-7038
Old 01-15-2010, 09:24 PM
Very good info. I have a 2002 996 C4S and I just realized that my oil filler cap has some white grease on the inside of the cap. Does this mean that my engine is due for a rebuild? My car has 36k on the clock.
Old 01-22-2010, 09:38 AM
TCallas's Avatar
No. The white greasy substance on your engine oil cap is most likely water and oil mixed and is probably just from short distance driving. When your car is at operating temperature for a while, it is allowed to burn most of the moisture out of the engine oil. Is there anything strange looking other than just plain green or pink coolant in your coolant expansion tank (don't open unless the engine is dead cold)? Does the engine dip stick oil look normal? It should!
Phone: 310-370-7038
Old 01-22-2010, 09:56 AM
Hurdiguirdiman
Hurdigurdiman's Avatar
Not according to this gentleman who changed he's with the engine in the car. YAHOO...finally did it.... - Rennlist Discussion Forums
Old 01-08-2012, 12:44 AM
Originally Posted by afast16v View Post
Tony Callas,
The white smoke and backfire issue would concern me a LOT. You might be dealing with an intermix issue or a damaged head. Don't run the engine until you get it checked out. If it is intermix, you could damage the main bearing to the point of a complete motor rebuild.
Tony G
10 Porsches come & gone!
1962 Morgan Plus 4
Old 01-08-2012, 04:01 AM
I replaced mine on my own without dropping the engine/trans. The total time from start to finish was approximately 5 hours taking my time and not rushing it. The part cost me about $135 at my local Pcar dealer.
You can confirm that the AOS is faulty by removing the oil cap. The car could stall or you will be able place your hand over the opening and feel the suction.
My comments and instructions are included on the following thread:
My AOS adventure... - Rennlist Discussion Forums
Alex
Old 02-04-2012, 08:59 AM
2001 Carrera Smoke from left tailpipe
I left my 2001 Carrera in the garage for 2 weeks without starting it. When I started it sounded like the oil was missing. It billows out white smoke from the left pipe and sounds a little like it is missing. This car has only 28,000 miles. I am worried...
Old 12-21-2014, 07:15 PM
Schnell Gelb
Back to the AOS.It is often cited as a problem.
This part has a diaphragm that fails and causes the problem$ discussed.10 cent part but $$$$ of damage potentially.
Has anyone developed a work-around to use a more durable part at a reasonable price?
There has been discussion of using a BMW part/generic pcv valves/Catch cans but no specific how-to.
The so called Motorsports AOS is just too expensive
2001 Boxster S
Engineers muse
Old 12-31-2014, 08:43 AM
PCA Certified D.I.
I would advise replacing the idler pulley bolts at least with a higher grade bolt. I had one fail (snap off) almost at idle, but was able to limp home with no consequences. I didn't know what the noise was at the time, or I'd probably have called the tow truck.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice"
Old 01-12-2015, 03:39 PM
