michael lang's Avatar
Throttle cable disconnection
In following the Bentley book for engine removal, it show that the throttle cable is disconnected through the cruise control and it is located in the left corner of the engine against the firewall. It's the servo just about the 'C'
However my car does not look like that. It is an updated version and I don't want to just pull the cable out. It uses a ball & socket located externally of the servo.
Can anyone advise the best way to disconnect the cable and get it through the bracket the cable goes through?
Thanks in advance.
Mike
'89 CARRERA
#402
Old 01-19-2014, 11:52 AM
French Import
zippy_gg's Avatar
There should be a clip like this that needs to be removed before you can pry the ball out of the socket
http://www.pelicanparts.com/catalog/images/misc/90016901402.jpg
Gilles
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2015 BMW K1600 GTL, 2011 BMW X3, 2016 BMW 435i hard top convertible
Old 01-19-2014, 12:04 PM
I don't remember seeing that type of clip although it's very tight in there. I'll check again, where exactly should I be looking?
Mike
'89 CARRERA
#402
Old 01-19-2014, 02:06 PM
French Import
zippy_gg's Avatar
The "head" wraps around the ball and the "spike" goes through the socket and secures the ball.
If you don't see yours it may just be missing. My car was missing one of them.
You may have to be forceful to release the ball from the socket...
Gilles
Old 01-19-2014, 05:16 PM
I figured it out. Had to remove the whole cruise control assembly
Three 10mm nuts and out it comes.
This exposes the clip that holds the throttle cable in the bracket
Using some curved needle nose pliers, I'm able to pinch the two plastic tabs together enough to get the clip through the guide
And out is comes
Mike
'89 CARRERA
#402
Old 01-26-2014, 09:39 AM
