Clutch actuator leaver arm
I've had to drop the engne and gearbox to fix various leaks and in the process have separated them.
Having removed the clutch small actuator leaver arm I now need to refit on the splines but what position do I fit it.
Because the engine and gearbox are separated the fork is free to move therefore I don't know what position the small arm should be fitted onto the splines in relation to the fork?
Should I mate the engine and gearbox back together first and then make sure the fork is in contact with the release bearing before I re-attach the small lever arm?
Any help gratefully received.
Old 01-24-2014, 02:14 AM
toddu's Avatar
It will be apparent when you mate the tranny and engine back together. Make sure you get fork in the bearing correctly during the process. The small arm is basically straight across, a spline one way or the other will be apparently wrong.
Todd
'81 SC
Old 01-24-2014, 03:27 AM
As I push the gearbox back on, should the fork slot onto the bearing easily or will I have to juggle it about? Do the arms of the fork sit between the inner and outer shoulder of the bearing?
Sorry for the daft questions but the more I look at this the less I understand it?
Old 01-24-2014, 04:51 AM
jmills's Avatar
I will be attempting this in the next couple of days and I am curious as to how this all goes back together too.
Joe
1984 Targa
2006 997 S
2005 Mazdaspeed Miata (track toy)
Old 01-24-2014, 05:51 AM
toddu's Avatar
The "ears" of the fork ride in the "channel" of the bearing. You can find pictures on here. You can view this through the hole at the top of the tranny. Put a little wheel bearing grease on the fork ends.
Todd
'81 SC
Old 01-24-2014, 05:54 AM
OK thanks for the advice.
Old 01-24-2014, 06:21 AM
pete3799's Avatar
Pete
79 911SC RoW
Old 01-24-2014, 06:24 AM
jmills's Avatar
I'm sure this is obvious when you mate the transmission and motor, but do you rotate the clutch fork with the long shaft it is attached to get it to sit inside the channel of the release bearing? I assume you look through the hole in the top of the transmission to tell what you are doing?
Joe
1984 Targa
2006 997 S
Old 01-24-2014, 06:30 AM
tobluforu's Avatar
Pretty much, yes. It might take 2 times to glide it in, but it's pretty damn easy once you see what is going on.
Old 01-24-2014, 07:27 AM
schumicat's Avatar
yes it is not hard with a flashlight and long screwdriver. it is easier if you have a helper so one of you can focus on the fork and the other manhandles the drivetrain, but it can be done with one man also.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-24-2014, 11:42 AM
Vintage Owner
Jack Stands's Avatar
Do you replace the actuator arm that rides on the release bearing automatically, inspect it carefully, or have the old one crack checked before putting it back together? If they do like to crack, I'd like to know if it's always necessary to replace the part with a new one.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 01-24-2014, 11:49 AM
