Go Back   Pelican Parts Forums > European Car Forums > Volvo Technical Forum
Porsche-Poor
bcoats's Avatar
Oil consumption issues
Not sure anyone is lurking on the Volvo Forums but in the event someone is out there have a strange issue with my 2001 XC70. I'm consuming approx 1QT of oil every 850-1,000 miles, car doesn't leak or smoke, could my rings be going, an independent says my valve seats are worn or cracked? Wouldn't it be smoking if that's the case? Any info greatly appreciated, terrified I have a ticking time bomb.
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 10-18-2011, 08:49 AM
jadewombat's Avatar
Mileage? Consumption seems a little high, but the car is 10 years old. My Ford F-150 has been losing about a quart every oil change and this started at 70,000 miles. I've had it since it was brand new, never missed an oil change, not excessively hard on it and it still uses oil somewhere. If you're really concerned about your Volvo you can have a shop do a leak-down test to determine where the loss is coming from, either the piston rings or the valves. This is a relatively inexpensive procedure or just buy the gauge and pull the spark plugs and check it yourself.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 10-18-2011, 01:37 PM
jadewombat's Avatar
Seems like this stuff has had good reviews.
Restore USA - Engine Restorer
Restore Engine Restorer
Gonna try it in my truck and see if it helps.
Old 10-19-2011, 09:01 AM
Porsche-Poor
bcoats's Avatar
thanks for the feedback, car has 78K on the odometer, tail pipe very black and sooty, think all signs here point to bad rings or leaky valve seats. . .
Old 10-19-2011, 09:06 AM
