onboard computer help...
Hi there,
I have a 98 328is with an onboard computer. Is there a way to make the onboard computer display turn on when you start the car? Everytime I start the car the display is off, and I have to push a button in order for it to turn on, I find that really annoying. Any help would be appreciated. Thanks!
Old 05-05-2003, 01:56 PM
Senior Advisor
Javier at Pelican Parts's Avatar
I always thought that it did turn on when you turn the car on,,ummm, strange. give the dealer a call, I think it can be re-programed via the modic connection.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 05-05-2003, 02:16 PM
stupenal's Avatar
Mine is off when i start up the car (unless there is some problem then stupid check whatevers light comes on). I like it that way, the obc is a novelty in the beginning, then just takes up space after awhile.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 05-05-2003, 04:40 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
If you have to press a button for it to come on, i would suspect tha something is wrong there. You should only have to turn on the car and it turns on automatically.
Old 05-05-2003, 04:51 PM
Exept for the clock, It will only display when a function button is pushed or if the check control senses a problem.
Old 05-05-2003, 09:46 PM
stupenal's Avatar
yeah, same here
Old 05-05-2003, 09:53 PM
hmmm...how come everyone is saying different things Jared is saying that I shouldn't have to push a button to turn it on, and others are saying that I/they do. I want Jared's computer then! Well maybe there's a way to program it to be on when you turn on the car. Anyone know for sure??? What's a modic connection? Thanks.
Old 05-06-2003, 09:46 AM
Well I do have an E30 rather than an E36, that is the first thing, sorry.
Old 05-06-2003, 09:48 AM
Senior Advisor
In the engine compartment ther is a large plug wher the dealer connects their sysytme to the car (modic) thats how they check codes and reprogram the computers.
Old 05-06-2003, 11:11 AM
supertack's Avatar
The right side of the unit is the 'time' & 'date' display, which is always on. The entire left side is an informational display that comes on when either prompted, or detects a problem. The temperature is one button, which only displays when you press it. Now the 'check control' button can be pressed to read fault codes, but usually says 'check control ok' unless you've got a problem. When a problem is detected, the yellow check control dummy light on the instrument cluster comes on first, in conjunction with the error description on the OBC. I personally haven’t found the check control feature all that useful. However under a few circumstances it has come in handy. I've got a minor leak in my coolant tank, so when the level dips too low, the OBC will flash "coolant level low-see owners manual" or something to that effect. It's nice cause it prevents you from missing something that could cause bigger problems. It's not an exact science though. I was getting a "break light failure" warning for a while, but after I replaced the bulb it appeared to be, the code persisted. Finally I replaced the 'plug n play' holder that the bulb sits in, & twists into the back of the light assembly. It finally worked.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-06-2003, 12:00 PM
I just use the clicker on the turn signal stalk to scroll through my pre-programmed display on the OBC. I hate reaching down for the individual buttons when I'm driving!
Old 05-07-2003, 04:26 PM
If i am correct, i believe that the OBC for the 3 Series E36 was the same used on the 5 series. Am i incorrect?
Old 05-07-2003, 04:30 PM
Not sure about the OBC for the 3 and 5 series....
Steve, I use that too, but it's just annoying having to push any button to turn it on. Wish it would just come on when you start up the car! I sent an email to a BMW dealer, still waiting for their response...
Old 05-07-2003, 04:57 PM
called the dealer and ask them if it was possible to reprogram, and they said no. i kind of find that hard to believe, becuz electronically speaker, that should be something quite simple. I dunno...maybe i'll call a different dealer and see if they say something else...
Old 05-09-2003, 08:36 AM
Nothing wrong with OBC. Only comes on if you have a prob.
Old 05-09-2003, 10:26 PM
