Popping noise in front end
I have a 96 BMW 328ic and it has popping noises in the front end. The car is in great shape with about 90,000 miles. There is a popping noise in the front end when driving on general roads without many bumps. Could this be something that is a typical problem? Has anyone had something like this on their car? Stabilizer? It isn't the wheel bearings and I don't believe it is the struts. Help!!!!
Old 02-20-2004, 10:16 AM
Sway bar end links would be one possibility. I've heard one way to check if it's them 'clunking' is to disconnect the end links and drive around the block - may not be detectable by visual inspection.
Old 02-20-2004, 10:52 AM
Thanks for the reply. I will probably try undoing them and seeing what happens.
Old 02-20-2004, 11:04 AM
