Thurmer85's Avatar
Send a message via AIM to Thurmer85
96 computer test list?
i have a 96 328i and if i hold the 10 and 1000 buttons a test screen comes up and asks you for a number 1-29 i tried them all and a couple do different things but only a couple worked most didnt i was wondering if anyone knows what each one is for or if there is a list somewhere thanks
Old 10-11-2004, 07:34 AM
Thurmer85, have a look below.
Stephen
Test numbers for E36 OBC
1 Display Test .. all LCDs and LEDs activate 2 Current Consumption in l/100km
3 Current Consumption in L/hour
4 Average Consumption (used to calc. Range) 5 Current Range
6 Not used ..
7 Average Fuel in Tank (l)
8 Current Speed (km/h)
9 System Voltage at terminal R
10 Country/Language
11 Units/ AM.PM
12 Average Speed (km/h) for calc. ETA
13 ETA
14 Date of software/mask of OBC
15 Production Diagnosis (??)
16 Production Diagnosis (??)
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous v. intermittent) 19 LOCK/UNLOCK all functions
20 Correction Factor for OBC Fuel Consumption (SEE BELOW!) 21 Reset all defect codes, date and time ... activate by pressing SET/RES
Note: #20 the factor is used to correct the OBC Avg Fuel Consumption figure to reality .. if your OBC is off a bit ... fill UP totally ... run tank down and refill ... calculate your Actual MPG ..
Now enter test 20 get the old Correction Factor .. NEW CF = OLD CF *(Actual MPG/OBC MPG)
enter the NEW CF using the numeric kays and hit SET/RES to store ..
PLEASE record you OLD CF so that IF you screw up you can always go back to what it was .."
E30 318i ................. Gone.
E36 325 tds ............. Gone.
E39 525d ................. Gone.
E39 535i .................. Resting
Panamera 3.0 diesel ... Daily driver
Old 10-11-2004, 09:07 AM
Stephen 325TDS,
What about HVAC test menu on newer digital climate control?
Old 10-11-2004, 09:59 AM
kocio67, sorry, don't know.
Stephen
Old 10-11-2004, 12:20 PM
Thurmer85's Avatar
Thanks for the list that was very helpful
Old 10-13-2004, 04:55 AM
No problem. Glad to help.
Stephen
Old 10-13-2004, 10:03 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
cool feature. I didnt even know about this...
Old 10-13-2004, 02:36 PM
