Question Want to change trans fluid...
I want to change my trans fluid for my getrag 260 and put some redline in, I can't seem to find any trans plugs/washers that i'll need to replace when I do this. I'm going to replace my differential fluid too, I found a new plug for it, is that all i'll need? Obviously never done this before, so take it easy
1982 911sc, 1990 535i
Old 10-18-2004, 10:34 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You dont need to replace the plugs unless they are damaged. There are also no sealing rings, the plugs thread into the transmission. You will need a 17mm hex key or socket to remove them.
Old 10-18-2004, 10:35 AM
I'm sorry for posting, I couldn't find my Bently manual. I just looked it up an noticed that, thanks for the reply.
Old 10-18-2004, 10:50 AM
no need to apologize, thats why the board is here....
dif
I apolagized because it was a waste of your bandwith
and what about my LSD? It just threads like the trans, no sealing rings?
Old 10-25-2004, 04:09 PM
Actually, no, the plugs on the diff use sealing rings.
Old 10-29-2004, 07:35 AM
33 12 1 212 461
33 13 1 214 100
Old 10-29-2004, 02:46 PM
