random missfire
1999 323i with 49k mi. check engine light came on at a stop light, then car began to idle very rough, borrowed neighbors snap on scanner and received codes, PO300 random missfire & PO304 missfire cyl.#4 I cleared the codes and took it for a ride check engine light back on and still very rough idle, checked codes, this time PO300 random missfire & PO302 missfire cyl.#2, any idea`s on what to check, or am I doomed for a trip to the dealer? any suggestions greatly appreciated.
In the shop at Pelican
What kind of spark plugs do you have?
The factory 100k mi plugs, bosch I think, also now the random miss codes are for all cyl`s and I`m now getting fuel trim rail codes
also is it my understanding that because this is a 1999 4 door it is a e46?
I cant tell you. Do you have the new or old body style
I would call it "new" style
get me the last seven digits of your VIN and I can confirm
the last 7 fp51934
its an E46
any more ides on the random miss at all cyl`s now?
WHat kind of a tool did you use to get those codes?
snap on scanner using the odb2 generic code reader
any other ideas where to look?? would the fuel rail trim codes be caused by the miss fire or vice versa? I have been told by my two local dealers that they sell a awful lot of coil packs( set of 6) for this car, I`m wondering if its the coil pack`s that are bad, I`m open for all suggestions
I just replaced all 6 coil packs and still the same problem, very bad miss at idle, sounds like someone tapping the intake with a ballpeen hammer, and the smell of rotten eggs at the tailpipe, any ideas??
just guessing but maybe its a fuel injecter(s) bad. I have a friend that her check engine light came on found out it was injectors were bad on an american car thou it was running really rough were her symtems
914 Geek
Often, the sulphur smell (rotten eggs) indicates a bad catalytic converter. Not sure how that could cause a misfire code or a fuel rail trim code. (Heck, I'm not even sure what "fuel rail trim" is!!)
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
well after the new coil packs the codes were,
fuel bank #1 fuel bank #2 randon missfire at cyl`s 1,3,5,6, so I guess I just might have to go to the dealer to let them hook it up to the computer ($95.00) and let me know what the problem is, I hope it is something stupid like the plugs ,but if it were, why the codes at all cyl`s? for random missfire |
if it is a broken cat would that be a item covered by emissions warranty? do you think that this would be a problem even though it has only 49k mi?
