Window switch problem?
I have a 93 325is and the driver side window switch does'nt want to go up sometimes! It goes down no problem.How do I get those switches out of there,do you just pop them out with a screwdriver or is there a certain way to get them out without breaking them.The pass. side light is also out in the switch.Please help? Thank you...
Old 12-31-2004, 02:32 PM
blkongry's Avatar
What are the symptoms? When you push the switch to roll the window up, does it just go a little bit, then stop? Then each time you switch again, it goes up a little further? Or are you sure it's just a contact issue within the switch?
I'm not sure on the removal, but here are some part numbers so you know what switch to get if you need to replace it.
Old 01-03-2005, 02:08 AM
