Having Trouble Programming Alarm Remote
Hi, it's a e36 318i 98 factory alarm. I already have one remote for the car that works fine. I am trying to add another, but can't get the darn thing to go into programming mode. I used the instruction from the alarm manual trunk open cycle car on etc... and the horn does no sound a chirp nor does the led stay lit to program. This is the same programming instructions I found on the forum.
Is there any special tips or tricks to do the programming that anyone else has experienced?
thanks
Old 02-26-2005, 08:50 AM
Do you still have the program instructions? I just got a used alarm but do not know how to program remote.
Thanks Rob
Old 10-10-2006, 06:19 PM
stupenal's Avatar
http://www.pelicanparts.com/bmw/techarticles/101-Projects-92-Alarm-Install/101-Projects-92-Alarm-Install.htm
read the section about programming the remote
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 10-12-2006, 04:40 PM
Author of "101 Projects"
Wayne 962's Avatar
Right - the article above *does* work, as I wrote it, and did it for my cars.
That said, if your door lock switches are faulty or not working properly, then you might have problems with the procedure. These are the switches that are located in the electronic lock assemblies, and often fail with age...
-Wayne
Old 10-13-2006, 03:07 AM
After you cycle the key 5 times do you have remove the key from the ignition?
Rob
Old 10-13-2006, 05:09 AM
Wayne, are the door lock switches also called door lock actuators? That said all my actuators work.
Thanks for you help guys.
Robert
Old 10-13-2006, 05:16 AM
Wayne 962's Avatar
Robert
The door lock actuators include the door switches as one unit, so if you need to replace them, you need to replace the whole unit. This is documented in the 101 Projects book...
-Wayne
Old 10-15-2006, 04:55 PM
Ok so since all my actuators work I shouldn't have trouble with the alarm install concerning door switches correct.
Old 10-15-2006, 08:39 PM
Wayne 962's Avatar
No, you can have the switches not working properly and the doors still locking. Signs of problems would be:
- alarm not arming properly
- windows not going up or down when the door is opened / closed on coupes
- gauge cluster blinking problems
- door chime going off when the door is closed
etc...
-Wayne
Old 10-16-2006, 01:10 AM
