MPG Gauge
I have a 94 318i auto that runs perfect. The question i have is where should the needle on the MPG gauge be at idle in drive? Mine disapears all the way to the right and then takes a few seconds to come back to mid scale after leaving a stop. As soon as I come to a stop again it swings all the way to the right. Is this normal?
Just shut the F*** up and ride/drive the thing.
Old 09-20-2005, 08:36 AM
blkongry's Avatar
Yeah, it's normal... the MPG gauge is based on speed and engine vacuum... if you are not moving, it disapears... you can't get a miles-per-gallon if you aren't moving ;-p~
Old 09-20-2005, 10:43 AM
Thanks, I just wanted to make sure.
Old 09-20-2005, 12:13 PM
Jeron's Avatar
Not that you need a second opinion but yup thats how it works.
An interesting note, on the E46 US it swings past 50 mpg to infinity but on E46 in CAN it swings to zero.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-20-2005, 12:17 PM
blkongry's Avatar
That's because Canadian's are much more pragmatic, where here in the US, we're a bunch of dreamers ;-p~
Old 09-20-2005, 01:08 PM
supertack's Avatar
;-p~
First time I've seen that one.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 09-21-2005, 08:45 AM
Jeron's Avatar
I read it on the internet so it must be true.
Old 09-21-2005, 09:34 AM
