E36 - Spark Plug Replacement
Just got done reading the excellent Pelican Tech Article on replacing spark plugs on an E36. My question is this - Does the battery need to be disconnected prior to replacing the plugs? The Bentley manual says to disconnect the battery prior to replacing the plugs. I've never done this before, however, I've never owned a car with spark plug coils and wasn't sure if this was the reason for disconnecting the battery.
Old 04-26-2006, 06:12 AM
Jeron's Avatar
I don't disconnect my battery for plugs but it wouldn't hurt, unless you dont have your radio code.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-26-2006, 06:19 AM
Eli at Pelican Parts's Avatar
I've done it several times without disconnecting.........
Never had a problem, I'm sure it's all precationary.
-Eli
Old 05-03-2006, 06:59 AM
