failed dme HELP!!!!
First off the dme got flooded so I replaced it then I replaced the
fuel pump relay then the crankshaft sensor and the camshaft sensor. then when I tried to start the car it would not start it would just turn over then it started grinding like it was the starter or something?? |
Your description isn't very detailed but if the starter is making a grinding noise it could be the solenoid which means you need a new starter. I don't think they are owner serviceable.
However, the first thing I would check is the battery.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Its a 94 318is and I think your right but what I cant understand is why
it would not start when it was turning over could it be the dme relay?? thanks |
I've had a bad battery turn the engine but not start on more than one occasion.
As far as the turning over for a bit then a grinding noise I don't know but it sounds like the starter. I don't see how a DME relay could cause a grinding noise.
The grinding has stopped but it still wont start its not getting fire
things I have replaced - dme, dme relay, fuel pump relay, camshaft sensor, crankshaft sensor, spark plugs and still no fire
could it be a problem with the other dme??? |
