OBC replacement
Help,
I've got the TIS manual on cd, but it locks up everytime I ask for the instructions on how to remove and replace the OBC. Anyone care to give me the instructions on this? Thanks,
99 323I Convertible 5 spd w/18 button obc
GG
Old 09-06-2006, 07:44 AM
supertack's Avatar
If your attempting to swap an 11 button OBC for an 18 button unit, here is the best write up I've seen on the conversion, lots of luck though.
OBC Conversion
If your just attempting to swap the same type of OBC, this should get you started.
OBC Removal
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 09-06-2006, 09:55 AM
Author of "101 Projects"
Wayne 962's Avatar
Is your unit broken? Or are just the light bulbs burned out (common mistake). The unit can be removed by inserting a credit card inbetween the top of the unit and the dash - then pulling on the unit. It should slide out. I think I have a picture of this in the 101 Book.
Bulbs are cheap and easy to replace - we sell them here on the sight in the catalog...
-Wayne
Old 09-06-2006, 11:53 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Wayne,
can I have the part # for the bulbs in my OBC? 94 325IC. thanx,
scott
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 09-19-2006, 02:17 AM
SCOTITUDE's Avatar
TYVM, I will add to my next order.
2008 E93 M3 DD
Old 09-20-2006, 02:29 PM
