OBC replacement
Help,
I've got the TIS manual on cd, but it locks up everytime I ask for the instructions on how to remove and replace the OBC. Anyone care to give me the instructions on this? Thanks, 99 323I Convertible 5 spd w/18 button obc GG |
If your attempting to swap an 11 button OBC for an 18 button unit, here is the best write up I've seen on the conversion, lots of luck though.
OBC Conversion If your just attempting to swap the same type of OBC, this should get you started. OBC Removal
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
Author of "101 Projects"
Is your unit broken? Or are just the light bulbs burned out (common mistake). The unit can be removed by inserting a credit card inbetween the top of the unit and the dash - then pulling on the unit. It should slide out. I think I have a picture of this in the 101 Book.
Bulbs are cheap and easy to replace - we sell them here on the sight in the catalog... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
can I have the part # for the bulbs in my OBC? 94 325IC. thanx, scott
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Should be 62-13-1-383-311-M97 on this page:
http://www.pelicanparts.com/bmw/catalog/shopcart/BE36/POR_BE36_ELlite_pg7.htm#item28 -Wayne
TYVM, I will add to my next order.
