Greasy Member
Spedo issues...
So here's the deal:
I was driving home from pool league this evening, and all of the sudden my spedo stopped functioning? I was driving along at 35mph and then out of no where it read 0 for about 6 blocks? Then almost a block from home it started working again... So the question is: Where is the spedo pickup in these (1990 325i) is it a tranny pickup, or is it an axle based sensor? thanks! Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
It's not out of the relm of possibility that the cluster electronics are going bad. If found these things have electronic issues left & right.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
The speedo pickup is on the diff. Did the odo stop when the speedo stopped?
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Greasy Member
Yes, the odo. stopped along with the spedo.
I have driven it a couple of times this morning, and have not had a problem? I guess it's time to crawl under her and take a peek. Thanks for the info! Nick
I would check for loose connections and frayed wires. If it happens again I would pull the sensor and see if it needs to be cleaned. If you end up replacing it you might consider a diff and tranny oil change as well.
Might was well take a look at the flexdisc at the front of the driveshaft while you're under there.
Author of "101 Projects"
Right - try the sensor first, it's easiest and cheapest to replace. The location of the sensor is documented in the 101 Projects book...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Greasy Member
Jeron, Wayne, thanks for the info. I am going to climb under the car this afternoon and check the spedo sensor. I also have to check my wheel speed sensors as every once and a while, at low speeds, the ABS will kick in. It only happens about once a week, but it bugs me.
I'll be sure to let y'all know what I find. Thanks, Nick
-Wayne
It probably is the sensor, but from memory the speedo signals pass through the SI (Service indicator board) on the way to the speedo/odometer. Bad connections, cracked solder joints etc can cause the speedo to drop out. Also there are a number of solder joints on the cluster board that can play up. Hopefully it is just the sensor!
Good luck -Mark |
not to mention....Grounds, grounds, grounds....
2) 85 325E, 80 3/4t Chevy restored need info on a 1977 aristocrat camper 17' by bendix homes. buy Bentley shop manual and 101 projects book - must have items |
On mine, intermittant speedometer was cured by re-soldering connections on the back of the speedo head. If you search a little, you'll find a description of the fix. Unfortunately, it's been a long time since I did that so I can't give you the link.
Don Hausman 86 325e 95 325ic Kubota B8200dt Cessna 175a (sold) |
Greasy Member
Ok, so I finally had a chance to work on the car! I have been a little busy since my wife gave birth to our first child on Friday the 13th
![]() Back to the car... I checked the sensor first and found that the wires did indeed need to be fixed. Since then, no problems! I also checked all of my ABS sensors, and found that some of those wires had broken insulation and were causing faulty signals, hence I fixed those as well. All I need now is to find a replacement chin piece for the front end, and I will be extatic with the car until I make a new list of things I want to do to it. ![]() Laters all, Nick
Sweet - glad it was an easy fix. Those SI boards can be a pain to troubleshoot...
-Wayne
Thread Tools | |
Rate This Thread | |
