| Registered Join Date: Apr 2006
				mirror control switch fail???
			my mirror wasn't moving when I tried to adjust it.  All I heard was the click noise from the mirror.  Is it the switch or the mirror? thanks for any input. 96 328ic 101700 miles | ||
|  10-24-2006, 06:19 PM |
| Moderator |
			If the noise is at the mirror then the switch is functioning and the problem is at the mirror.
				__________________ HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 | ||
|  10-25-2006, 06:26 AM |
| Author of "101 Projects" |
			Right - sounds like corrosion or something wrong with the mirror motors.  Although there are two motors in there, and usually one stops working and the other continues to work.  Is this the case, or is the mirror just dead? -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  10-25-2006, 10:18 PM |
			Its been that way since I bought the car.  Both mirrors are not working, so I thought it was the switch.  Sometimes I kept on hitting on the switch and the driver side would move for a second, but only to one direction.  I was thinking about getting new switch but just want to ask for help before doing so.
|  10-26-2006, 02:55 PM |
| Moderator |
			It is possible it is the switch and it is only contacting momentarily.  I was envisioning a constant noise in the mirror.  You should be able to pull the switch and test it for continuity.  You could also pull the mirror and test it for power while someone runs the switch.
|  10-26-2006, 06:07 PM |
			Just replace the switch, it pops right out: -Wayne
|  10-27-2006, 04:16 AM |
