| Registered Join Date: Jul 2006 Location: Dallas
				Headlights flashing when idle
			I have a 92 325iC, and for some reason when the car is at idle, the engine temp needle bobs, the headlights and instrument cluster lights flicker, and the idle goes up and down slightly.  Is this a problem with the idle relay????
|  10-13-2006, 07:44 AM |
| Moderator |
			Sounds like an electrical issue.  Put a multimeter on it and see what you voltage is and if it fluctuates.  I cant remember what the running voltage is but I guess around 13.5 and it should be static.  You may have a bad voltage regulator, a loose connection or bad ground.
				__________________ HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 | ||
|  10-13-2006, 07:50 AM |
| Author of "101 Projects" |
			Check with the "Solving Electrical Problems" Project in the 101 book - it shows the common locations of the ground straps - sounds like that could be your problem... -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  10-15-2006, 03:53 PM |
