Headlights flashing when idle
I have a 92 325iC, and for some reason when the car is at idle, the engine temp needle bobs, the headlights and instrument cluster lights flicker, and the idle goes up and down slightly. Is this a problem with the idle relay????
Old 10-13-2006, 08:44 AM
Jeron's Avatar
Sounds like an electrical issue. Put a multimeter on it and see what you voltage is and if it fluctuates. I cant remember what the running voltage is but I guess around 13.5 and it should be static. You may have a bad voltage regulator, a loose connection or bad ground.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-13-2006, 08:50 AM
