rotor thickness: what tool to use to measure?
Hi all-
first post on this forum. I have never done rotors before (this is for a 98 m3, btw) and I want to be able to measure the rotor thickness before I jump into this project. I know that I cannot use a regular caliper since that will simply read the thickness of the outer lip. I need something that will be more like a C clamp caliper. I was at NAPA yesterday, and they had a nice digital C sytle caliper made for measuring rotors, but it was $76! I'd rather not hafta pull the rotors off the car and take them in just to have them measured, but $76 seems like a lot given that I will use it only once a year or so at most. I guess what I am asking here is... what are my alternatives? Are there cheaper, but accurate digital c-style calipers that I can get over the internet? Or should I buy a non-digital c-style caliper? (I am a little hesitant to get the non-digital as I expect that they may be harder to read... and being a begineer, I want the measurement to be as simple as possible.) Could anyone recommend a good low cost tool to do this? Input would be appreciated.... thanks, dan |
nevermind. Just ordered this digital brake micromenter
Get your normal calipers and grind out the back of the jaws!
Bugger this for a joke... |
I have the Fowler in non-digital but for the extra $20 the digital seems like a good thing.
You made a good purchase.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
I dont know how exact you guys need to be to check minimum spec on a rotor for replacement. I use an open end metric wrench on the end of the rotor. Cant get any cheaper. If its close to min spec its garbage.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Also the amount of wear between new and min thickness on BMW's rotors is about 1.5mm, thats .75mm on each surface, so it needs to be reasonably precise.
Author of "101 Projects"
We sell a bunch of these right here on Pelican (for cheaper than Amazon!):
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=312471&command=DWsearch&description=micrometer -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thread Tools | |
Rate This Thread | |
