jb6983's Avatar
hello,new here.325 power problem
hello,i just purchased a 95 325ic with 90k.the car runs great accept for a strange problem.after i drive the car for a while then park it when i get back in it to go i put the car in drive and you cant give it gas for a few seconds,i mean the pedal is fine and the linkage is fine the car will only idle while giving it gas to go then all of a sudden you here a tiny pop and it-goes fine.the asct light is also on.like i said when i first start the car for the day it is fine but the rest of the time after i park it does this.it only last about 10- 30 seconds but it is strange.i almost got hit pulling out in traffic.you can pump the pedal and nothing then pop its fine..any input would be great..thanks for all the help and nice to meet everyone,jeremy
Old 07-11-2007, 05:25 PM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Seems to be a common issue with these cars. Suggest you start with plugs, boots, coils, throttle position sensor in that order!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 07-12-2007, 08:34 AM
i suggest you find out what the dsc light is on for. then take it from there. is your car an automatic?
gONe
Old 07-12-2007, 03:43 PM
jb6983's Avatar
yes it is automatic.ive been reading that if the asc-t light stays on that there is a problem and that it will make the engine lose power as that is what the asc-t is supposed to do when needed,just not all the time..im not sure..
Old 07-12-2007, 05:12 PM
Jeron's Avatar
Probably a wheel speed sensor.
Turn off or disable the ASC and see if the problem continues.
To disable it disconnect the connector on #8 here:
http://www.realoem.com/bmw/showparts.do?model=BJ63&mospid=47475&btnr=13_0391&hg=13&fg=15
Yours is probably OBD-I so you may have to go to the dealer for diagnose which speed sensor or pull them all and clean them.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 07-13-2007, 08:43 AM
