Rattle comming from rear end
Hi all,
I'm hoping that someone will be able to give me a couple of pointers to the source of a rattle i have coming from the rear left of my 323 saloon.
i have replaced the rear sway bar links and checked the rear top mounts but the rattle still exists.
it is definitely suspension related. any ideas??????
1997 323 i SE Saloon - UK Spec
Old 12-09-2007, 04:59 AM
Could be your rear trailing arm bushing or subframe bushing.
Old 12-09-2007, 03:05 PM
Jeron's Avatar
Rear shock mounts are the most common. Re-double check them and Yuricks comment.
Eliminate the brake pads as a source by testing the rattle while braking. Check the exhaust hangers.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-09-2007, 03:19 PM
another rear shock mount suggest by jeron, what a supprise. when does it make this noise around turns over bumps leaving a stop, coming to a stop try to pinpoint when it is happening.
gONe
Old 12-12-2007, 04:20 AM
