Banned
Setting M10 Timing?
Hey everyone, I just recently picked a 1984 318i from a friend of mine for next to nothing, it needed a head gasket and a few other minor bits, but nothing really major, and if nothing else it seemed like something fun I could tinker with then resell. Turns out the head gasket had just been replaced by another friend of mine, and for whatever reason he used a gasket sealer on the head gasket, and I have to be honest, going to all the work of replacing the head gasket knowing it had just been done, and needed to be done again because my friends are idiots is a bit frustrating, but it wasn't too bad, it took me about 4 hours to get to where I am. Which brings me to my question...
Right now, everything is back together, all I need to do is put the cam gear on, set the timing, and then put the timing cover and valve cover on, then it should be good to go. Which leads me to the one roadblock I ran into on this project. How do I set the timing on this engine? I can see the timing mark on the cam gear, as well as the distributor, but the crank is where I reach a problem. I can't see any marks or anything indicating top dead center. Last time my friends did this they had a shop set the timing for them, and that cost $350, not something I'm trying to spend when I know I can do it myself. Can anybody tell me how to do this? Also, one more question. What size socket do I use to turn the crank? I went up to 27mm, but it's bigger than that, and I don't have any bigger sockets, so before I buy a bunch to guess and check, I'd like to know the right size from the get go. Thanks guys. |
I suppose an adjustable wrench and a ruler could get you the crank bolt size.
For TDC, you can put a screwdriver in the #1 spark plug hole and watch for TDC then put a drill bit or 3/8"socket extension into the flywheel lock hole on the bellhousing near the starter to hold it there. The Tech Info Center has articles on head replacement and timing that may apply but if not I'm sure the timing procedure is on the web.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Banned
I suppose you're right, that is a way to do it, I was just wondering if anyone knew the actual size, but that is a good idea, thanks.
I also never thought about the screw driver idea, another good little trick that I completely forgot about. I also did check the tech articles, but anything pertaining to the M10 engine is completely absent, they are fantastic articles for M20s and the like, but I'm pretty much S.O.L. with the lowly 84 318i, but that should definitely be enough for me to be able to figure it out, thanks. |
Here is the M10 procedure from a shop manual.
There's not much to it just align all the timing marks. Refitting 12 Refit the tensioner rail and chain guide rail, if removed. 13 Temporarily refit the lower timing chain cover and vibration damper, so you can check the crankshaft timing marks. Once you’ve verified the TDC marks are aligned, remove the damper and cover. 14 Loop the timing chain over the crankshaft sprocket, then loop it over the camshaft sprocket and, guiding the chain between the chain guide and tensioner rail, refit the camshaft sprocket on the camshaft. Make sure the camshaft timing marks are aligned. 15 The remainder of refitting is the reverse of removal. Be sure to tighten the fasteners to the correct torques (see this Chapter’s Specifications).
Banned
Awesome, that's just what I needed, thank you very much.
