supertack's Avatar
Front End Vibration
1997 328is
I seem to have an intermittent issue with front end wobble or vibration. This is not a constant, & is variable to my speed.
At around 40mph, it feels like my front end is vibrating from side to side. This can not be seen by looking at the hood. The steering wheel also seems to wobble from side to side slightly. When it's happening speeding up doesn't seem to stop it, but slowing down does. It doesn't happen every time, just intermittently.
I'm guessing either alignment, or tire balancing. I thought I'd start with having the tires rotated & balanced. I had the alignment done last summer, so I wouldn't think it would need it again so soon; however with this brutal Chicago winter, there have been a multitude of potholes that have been tough to avoid. It's almost been like street acne up here.
Thoughts?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-05-2008, 04:14 AM
Make sure that the tires are properly balanced and inflated first. These will be the easiest and cheapest thing to do.
Old 05-05-2008, 07:02 AM
Jeron's Avatar
Try swapping tires F-R.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-05-2008, 08:59 AM
If swapping the tires doesn't help, see if the rubber is cracked on your control arm bushings.
How many miles on the car? and have you had any front end work done?
May need front control arms and bushings. I just did my 93 and what a difference.
It's like I attached a new car to an old steering wheel.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 05-06-2008, 08:39 PM
supertack's Avatar
Had a tire rotation & alignment done. Helps, but not completely gone. Shop that did the alignment said the front ball joints were bad & needed replacing.
Does this sound right? Quoted price of $200 each for ball joints or $450 for control arm that would come with both ball joints.
Car has a tad over 100k on it.
97 328is
Old 05-21-2008, 10:31 AM
Does that include labor?
Old 05-21-2008, 10:42 AM
Jeron's Avatar
Does it include labor and is the price for both side or each side?
Check out the control arm prices on Pelican for comparison.
Old 05-21-2008, 11:27 AM
supertack's Avatar
No labor.
Price of $200 each ball joint. Something seems wierd, Real OEM shows ball joints @ $47 each. Is that right, or am I looking at the wrong thing?
97 328is
Old 05-22-2008, 07:05 AM
It does sound excessive. I would check to see what Pelican and other internet auto part companies charge for the same parts first.
Old 05-22-2008, 08:05 AM
Jeron's Avatar
Seems very high. I didnt check but I think ball joints are in the $50 range and arms are 150-250 each.
I would replace the whole arm and CAB. Consider DIY.
Old 05-22-2008, 09:12 AM
supertack's Avatar
I can't find the control arms on Real OEM. It's not the 'wishbone' is it? The only ball joints I find are $47+ each.
I was told that the control arm comes with the ball joint. Correct or false?
97 328is
Old 05-22-2008, 09:57 AM
Jeron's Avatar
Yes, it's the wishbone.
I believe the arm comes with both balls.
Old 05-22-2008, 11:13 AM
Don't forget the control arm bushings, You have to replace them when you do the control arm.
If you only have around 100,000 miles, you may only need the bushings. Did you see if the rubber was cracked on them? Do you have any play in your ball joints when you you check them??
I have changed the bushings without removing the control arms. You can even buy the bushings already loaded into new brackets(eliminates the press out and in of the bushings).
I think I paid less than $20 for both bushings a few months ago. I think the pre-loaded ones where over a hundred.
Old 05-22-2008, 05:48 PM
