Transmission conversion to manual, differential swap neccesary?
Hi i converted my 89' E30 325is to manual, using parts out a wrecked ecology 91' E30 325is. Now i feel like i rev up too fast in first, without really getting too much speed. Not a clutch problem, just have to shift too soon, it feels like. So i put bigger tires in the back and now it feels good. I was wondering if my 89' automatic differential is different from a 91' manual transsmisions'. or if your just meant to shift out of first real fast like.
Old 01-12-2009, 07:53 PM
HI i just found this answer elsewhere...
"The diff ratio multiplies torque, the engine output does not change.
The 4.10 ratio enable the engine to run at a higher rpm where it produces more power because the auto tranny absorbed more power than the manual tranny. In '89 the 5-speeds had 3.73 ratio and the auto had 4.10. Have you verified the ratio via the wheel & driveshaft turn method?"
soo excited that is why it felt off cause i need a manual trans differential. one last thig though are all 5spd in the E30 alike, that is to say same ratios, and is there a 3.73 differential with LSD?
Old 01-13-2009, 12:38 AM
Jeron's Avatar
Try diffsonline.comto answer your question.
Yes, auto trannys usually have a quicker ratio.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-13-2009, 09:54 AM
Cool got it, so i will just get the 3.73LSD out of some junkyard car and i'll be good to go. probably like up to 15mph in first at 3000rpm. I was wondering though, what is the difference between the getrag 260/5 and the ZF manual. witch is german, either? And witch is better? stronger or lasts longer? This is for the 89' - 91' E30's. wich is the prefered manual tranny to have?
by the way witch is the getrag, the smooth one or the one with crosshatched ridges? thanks for any leads
Old 01-13-2009, 10:43 AM
