O2 sensor problem
'99 323is, manual, I had a problem with balking acceleration,cutting out and missing between 1000rpm and 2000rpm, checked and got a "Pre Cat O2 sensor code". I changed the O2 sensor closest to the cat, still same problem, same code, changed the other O2 sensor, same problem, same code. All I can find are just these two O2 sensors, is there a third O2 sensor further up on the header down pipe? At 70 mph on the high way I get 30+mpg just like I have for the last 120K, acceleration in 1st and 2nd can be balky unless I feather the gas pedal . I really dont want to go to BMW for repair, any ideas will be appreciated.
Old 05-18-2009, 02:17 PM
I am not certain about the 323, but it should have either three or four sensors. Either two fronts and one rear, or two fronts and two rears like a 328. If your exhaust manifold is split into two banks of three, it has two sensors.
Old 05-18-2009, 08:57 PM
Jeron's Avatar
What was the exact code?
You should have two precat sensors. They in the engine bay on the manifold.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-19-2009, 08:38 AM
I have found and changed two pre cat sensors, both are before the cat and after the exhaust down pipe. Since I have changed both sensors what could be causing the pre cat sensor code?
Old 05-19-2009, 08:43 AM
Jeron's Avatar
It depends on the code.
It could be a damaged wire.
Old 05-19-2009, 11:24 AM
The car is in the shop right now, it is stuck in first gear, dont ask me I dont have a clue as to how or why, anyway, when I get it back I will confirm the code and check the exhaust manifold for more sensors. I dont remember the code number , but in he Peak book it was "Pre cat O2 sensor".
Old 05-19-2009, 11:36 AM
