Rough idle fixed then returns on my 318i
I had a rough idle and stalling on my 1993 318i with occasional dark smoke coming from the tailpipe. I changed my mass air flow meter and the car ran perfect for 24 hours and 50 miles. Then the rough idle came back and the smoke is more constant but the car does not stall. Any ideas on my problem?
Old 11-04-2009, 10:46 PM
1990 325i
KellyGuido's Avatar
Did you replace the wire connector? My 325, the connector comes loose and if i push it on it will say on for a day or two then it acts up again.
The Music has Stopped Playing, but My Ears are Still Ringing!!
1990 325i, 1997 VW golf, 2000 Camry
Old 11-05-2009, 02:49 AM
Jeron's Avatar
Have you checked your crankvase vent valve(PCV)?
How strong is the suction at the oil cap? The engine stumble and recover when you remove the oil cap. If it does not stumble and there is strong suction then your PCV is bad.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-05-2009, 07:44 AM
Thanks for the input. I'll check the plug, pcv, and oil cap in the morning.
Old 11-05-2009, 09:22 PM
My 318i is running rich. Any thoughts.
Old 11-13-2009, 09:17 PM
