big al (guest)
Guest
Posts: n/a
I have a 2002 325i. Getting code 1085 running lean. Could it be a fuel filter causing the problem. It is the original fuel filter.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Reading BMW Fuel Injection Fault Codes
Old 02-27-2011, 11:23 AM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, it might be caused by a clogged filter, but I would guess probably not. Still, changing the filter is probably something you want to do, and it's also probably one of the easiest things to do, so I would indeed start there and then see if the code continues to be triggered.
- Wayne
