Si e30's Avatar
Send a message via Yahoo to Si e30
M Logo Cluster Problem
Hi there,
Yesterday morning I found the needle tachometer not in "0" position, it stop in "1" mark in the gauge, try to switch the key on to "2" position the needle moved to "0" than I try to switched the key off, than within 4 second the needle move to "1" and will repeated once I switch the key off and on.
if I run the engine the needle read the engine speed normally
what went wrong here..
thanks...B4 guys
Old 04-04-2011, 11:02 PM
Rrrockhound's Avatar
See this article:
Pelican Technical Article: Replacing Service Indicator Board Batteries on the E30 BMW 3 Series
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 04-05-2011, 02:06 PM
Si e30's Avatar
thanks for advice bro,
the batteries already change but the problem remain the same,have check the pulse sender from MCU it work normal as it is , after cut the Power in the blue socket the tacho will sit at "0" after re connect the problem remain the same, is it possible because of Si board defective or something else
Old 04-07-2011, 07:49 PM
been there, my 88 cabro did the same thing. replaced the batteries and still, no tach. found a suposidly good si board on ebay, and still no tach, odomited or fuel economy guage. found a used cluster on line, and thewy even set the miles for me to the old cluster.
it worked!
if you would like i will try to find the site i got it from. been 6 or 7 years.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 04-11-2011, 10:18 PM
Si e30's Avatar
M Logo
bro the weird thing is tacho,EC,Temperature,spedo and fuel woks normal. my problem will happen once the ign. switch turned off than the needle will move to "1" with in 4 second.
any way I would like to try, thanks b4 bro
Old 04-12-2011, 11:38 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Check the nuts holding the cluster together. They are the ground points for the cluster. If they are loose, it wont ground correctly.
Old 04-13-2011, 06:45 AM
Your problem doesnt sound like the SI board, it sounds more like a sensor or a loose conection is giving eronious information to the tach. The tach gets its signal from the ecm and the ecm gets its information from the crank positon sensor.
If it turns out to be a bad tach, i have one I dont need. I dont have the car anymore.
Old 04-13-2011, 07:21 PM
Si e30's Avatar
bro, appreciate with picture if Possible, if you mean the nut which hold the Temp.control and Fuel level indicator, they already have a good grounding.
and for the sender from MCU, already cut out the wire..remain the same
and for the spares which you have it,can I get the detail?thanks B4
Old 04-14-2011, 12:51 AM
It is in GPM, US version. It worked when removed. You can have it. The only thing I know about indonisia is it is not close to Florida. Next time your around, let me know, I'll leave it on the front porch.
Old 04-14-2011, 08:01 PM
Si e30's Avatar
thanks Bro, I have no plan to come to Florida in short time . if possible to have it, the Freight bill I will pay , but give me an Idea for total cost.
Thanks again Bro
Old 04-14-2011, 08:18 PM
Don't know. If you find you need it, you can have it. Find out what it will cost and how to do It, and I don't mind putting it in abox for you.
Old 04-14-2011, 09:29 PM
Si e30's Avatar
Bro coolbear-1,thanks for your help please send the detail to my mail address sasongko_andreas@yahoo.com
I think we can use EMS.....
Old 04-15-2011, 01:55 AM
