A/c compressor problem
a/c compressor only runs if i hot wire it with 12v from battery...front electric fan must also jumped via wire in therm. plug...blower fans and everything else seem to work fine...whats up?
Old 04-10-2011, 06:30 PM
bostongrun
A/C Relay
Old 04-10-2011, 08:52 PM
installed relay...nothing
Old 04-11-2011, 04:53 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Might help if we knew what car it was for...
The problem is likely either the high or low pressure cutoff switch. Meaning you either have to much or too little refrigerant in the system.
Old 04-11-2011, 10:51 AM
sorry...1997 328i
Old 04-11-2011, 04:29 PM
got 32lbs low side
Old 04-11-2011, 04:31 PM
Mark,
Do you have a wiring diagram for your car? If so, do you have a good digital meter?
I can help you diagnose the problem.
You have to start at the source and work through each component eleminating them as you go untill you find the one that is faulty.
Hard to do it without a meter and a map though.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 04-11-2011, 08:27 PM
