Question does Motronic re-learn optimal idle mix?
on my 89 E30/M20, i just replaced:
fuel pump
fuel pressure regulator
fuel pump replay
oxygen sensor relay
now @ start, the car runs (a) a little lower idle RPM, and (b) richer and rougher than it used to.
i suppose different pressures/resistance are possible/likely after the parts replacements. (?)
does Motronic "re-learn" overtime and smooth out settings?
if so, about how long does that take?
if not, what's next to 'cure' the rich/rough idle?
Old 05-18-2011, 11:00 AM
Si e30's Avatar
Send a message via Yahoo to Si e30
M Logo
bro,
probably the fuel Pressure not match with the requirement, check it with pressure gauge
hope can give a clue
Old 05-19-2011, 01:22 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
What do the spark plugs look like? What kind of plugs are in there?
Old 05-19-2011, 09:23 AM
they're "Bosch WR8LC+ Super". pulled 2, look nice & clean.
Old 05-19-2011, 09:45 AM
Those are the right plugs.. This one is really odd. Have you done the stomp test to check for codes?
Pelican Technical Article: Reading BMW Fuel Injection Fault Codes
Did you check the Aux. Air Regulator? Are ALL vacuum lines in good shape?
Old 05-19-2011, 09:55 AM
yep, both the 'stomp test' and my Peak Research R5/FCX too say 'all OK' ...
yep, all vacuum lines are OK.
aux air regulator? new one on me ...
i've an '89 325i E30/M20 auto trans. can you 'point' to what you're referring to @ PelicanParts catalog?
Old 05-19-2011, 10:22 AM
the Aux. Air Regulator is also calle dthe idle control valve. One of the things I like to do is remove it from the intake manifold and spray carb cleaner inside the mechanical portion of the valve. They sometimes stick due to oil residue.
Take a look here.. Number 5
RealOEM.com * BMW E30 325i Volume air flow sensor
Old 05-20-2011, 08:36 AM
ah. i'd already done that ... ICV removed and cleaned. no sticking, no change :-(
Old 05-20-2011, 08:49 AM
