on my 89 E30/M20, i just replaced:
fuel pump fuel pressure regulator fuel pump replay oxygen sensor relay now @ start, the car runs (a) a little lower idle RPM, and (b) richer and rougher than it used to. i suppose different pressures/resistance are possible/likely after the parts replacements. (?) does Motronic "re-learn" overtime and smooth out settings? if so, about how long does that take? if not, what's next to 'cure' the rich/rough idle? |
bro,
probably the fuel Pressure not match with the requirement, check it with pressure gauge hope can give a clue |
In the shop at Pelican
What do the spark plugs look like? What kind of plugs are in there?
they're "Bosch WR8LC+ Super". pulled 2, look nice & clean.
Those are the right plugs.. This one is really odd. Have you done the stomp test to check for codes?
Pelican Technical Article: Reading BMW Fuel Injection Fault Codes Did you check the Aux. Air Regulator? Are ALL vacuum lines in good shape? |
yep, both the 'stomp test' and my Peak Research R5/FCX too say 'all OK' ... yep, all vacuum lines are OK. aux air regulator? new one on me ... i've an '89 325i E30/M20 auto trans. can you 'point' to what you're referring to @ PelicanParts catalog? Last edited by Aresby; 05-19-2011 at 10:42 AM.. |
the Aux. Air Regulator is also calle dthe idle control valve. One of the things I like to do is remove it from the intake manifold and spray carb cleaner inside the mechanical portion of the valve. They sometimes stick due to oil residue. Take a look here.. Number 5 RealOEM.com * BMW E30 325i Volume air flow sensor |
ah. i'd already done that ... ICV removed and cleaned. no sticking, no change :-(
