1984 325 e Need to replace odometer
How do I do it?
Why do you need to replace it? Is it not working? Because it can be fixed.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
In the shop at Pelican
The odometer is usually replaced as part of the whole instument cluster. YOu dont usually see the odometer separate.
The odometers can be fixed.. Try North Hollywood Speedometer or Palo Alto Speedometer. |
The odometer is an easy DIY fix if the problem is just stripped gears.
odometergears.com has parts, instructions, and good close-up pictures.
