R@j (guest)
Guest
Posts: n/a
A**** The Best possible support provided, with this a beginner can act a pro!!!!! People should donate to whom provided all these detailed pictures and text I would like to !!
Quick suggestion,, To open the top torx bolts on the gearbox, remove a few pipes from the engine compartment near the slave cylinder and you will find you can fit your arm hand - into towards the bolts, easy = use a small spanner a torx or an star shape 10 - small rachet.
Hope this helps !
Any questions about BMW or MERCEDES - German cars welcome ??
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Clutch Replacement
Old 12-18-2011, 10:15 PM
thanks for the tips..
Old 12-19-2011, 09:53 PM
Jeron's Avatar
Also consider that the engine itself can be tilted a few degrees to allow better access to the top tranny bolts.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-27-2011, 10:17 AM
