kbana (guest)
Guest
Posts: n/a
Out of curiosity, since metal expands when heated, why not simply remove the sensor just after a drive when the exhaust is hot. Yes you may burn yourself, but that's what gloves are for.
Will this work better? - I am about to attempt a sensor replacement after ordering one from Pelican Parts :
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Oxygen (Lambda) Sensor
Old 07-25-2012, 04:59 PM
Nick at Pelican Parts's Avatar
The sensor will expand in the hole as well as the mounting bung. Best to do it cold to protect the threads in the bung and yourself.
- Nick
