Andrew (guest)
Guest
Posts: n/a
Hi, i am driving a bmw 330i 2011 and the car runs fine but sometimes when i press the throttle to go fast a little bit the car shakes a bit but mot hard as if someone pushed the car it happens from time to time and also happens sometimes when i take my foot off the gas instantly, what could this be. And i have another questions, bmw here in egypt told me you dont change the transmition oil ever unless u have a problem with my transmission and the car is 85,000 km so far is that true or not. Thank you in advance for your help i really appreciate it.
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-11-2014, 11:25 AM
Nick at Pelican Parts's Avatar
You could have an engine misfire or a drivetrain issue. I would check or fault codes to start.
You should be able to pay for trans service if you need it. Find an independent mechanic willing to do it if the dealer will not.
- Nick
