Suso35 (guest)
Guest
Posts: n/a
Thanks for your reply.
Went to workshop and did the diagnose and it appears O2 SENSOR FAULT CURRENTLY PRESENT.
I bought the BOSCH 4 wire o2 sensor and now the foreman said the wire length is different with the currently plugged on my car. Will the wire length be a problem here?
Car is 94 325 model and only has 1 o2 sensor. Is this correct?
On the wire's length, can I just plug it in without doing any alteration on the length?
Thanks in advance.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-11-2014, 06:28 PM
Nick at Pelican Parts's Avatar
If it is a little longer, it should be OK. Just be sure the wiring is routed safely.
- Nick
