benbimmin (guest)
Guest
Posts: n/a
Hey guys I need your help so the heater wire of my o2 sensor got shorted because it touched the exhuast I got a universal one from online and thought I could do it myself & it burned basically my car doesnt start & when it does it quicky dies it throws the code 1111 ? I replaced DME but it just cranks any ideas ? Thanks in advance
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-04-2015, 03:24 PM
Nick at Pelican Parts's Avatar
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
