Question Starter problems
Hello,
325i 1993 24 valve
I have a starter that works intermittently, sometimes its fine other times nothing, no noise at all.
I'm thinking maybe the starter relay is going. Can someone tell me where it is under the hood? Or the trunk?
Old 11-27-2002, 10:13 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Re: Starter problems
Originally posted by saintex
Hello,
325i 1983 24 valve
I'd be happy to tell you, however, there is no such thing as a 1983 325i, especially with a 24 valve engine.
Maybe a typo?
Old 11-27-2002, 10:14 AM
ooops '93
Old 11-27-2002, 10:16 AM
Question
Anybody?
Old 11-29-2002, 12:25 PM
Saintex,
I wouldnt start looking at the relays just yet. The first thing I would suggest is checking the battery. So many times, I have solved starter problems simply by cleaning and tightening battery posts and cables.
I have also seen situations where over time, battery cables build up internal resistance due to oxidation, heat etc.. When this happens, it is impeding the flow of current from the battery to the starter, or from battery to ground.
I'd check these two things before i assume the starter relay.
Old 11-29-2002, 12:59 PM
Thanks I will check out what you suggested
Old 11-29-2002, 01:03 PM
