edirty6 (guest)
Guest
Posts: n/a
So I've recently cut my exhaust young kid doing stupid things on my 96 328i and now I'm experiencing my RMPs dropping low and then shooting back up to the spot it was at while driving at a constant pace and then trys to stall. I believe its my o2 sensor which could be causing the problem? idk
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 01-21-2016, 05:50 AM
Nick at Pelican Parts's Avatar
Could be a vacuum leak. I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
