Urke (guest)
Guest
Posts: n/a
Question on BMW 3-Series E30 Idle speed troubleshooting
Hi, my '89 525i E34 m20b25 have a bouncing idle after a engine rebulid, when is started everything seems to be ok, idles at 800 but 1 or 2 minutes later the idle starts to bounce, at first the idle bounce beetween 800 and 1000 gradually getting worse untill it reaches 1800 rpm,really anoying while driving in town, i replaced nearly all hoses, icv is new ,tps seems to be ok so the afm.
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Idle Speed Troubleshooting (1983-1991) | Pelican Parts DIY Maintenance Article
Old 11-22-2016, 09:22 AM
Nick at Pelican Parts's Avatar
if you remove the ICV and control air flow to the engine to reach 750 rpm, is idle smooth?
- Nick
